Iam using jetson nano development kit 4gb ram .my project title is people counting using yolo v5 and pytorch. It runs only 3hr, output file stores only 1 hr video.after that it hangs.I need a module for people counting ,please help me to buy long duration board.
Would you mind to check the system status with following command?
$ sudo tegrastats
It will be good to see if there is any memory leakage in your program first.
