Hi again,
I am having no end of trouble trying to tame videoSource and videoOutput with innumerable …
[cuda] unspecified launch failure (error 719) (hex 0x2CF)
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/codec/gstEncoder.cpp:575
The errors start at different places each run so I cant find a pattern.
If I keep it simple it doesn’t complain but what I am after isn’t that complicated.
I assume I am stretching what these libraries can do but I have no rules of thumb to go by.
In one thread running about 20 times/sec, is uses one videoSource ‘csi://0’ and 2 videoOutput
One is a mp4 stream image for image from the source; this ‘swaps’ output files every minute or so with outVid.Close() then outVid = jetson.utils.videoOutput with a different file name.
The second is a periodic snapshot jpg.
The videoSource puts each frame into a cuda buffer in global space for other things to read
Meanwhile there is a second thread, running about 10 times / sec, that catches the image from global space
then does a segnet analysis on it and creates a third videoOutput of the overlay after the analysis.
It also annotates the image via jetson.utils.cudaFont OverlayText
This also swaps files every minute or so.
Once the program gets upset it will cascade errors everywhere. If often requires a reboot to get any sense back.
And every now and again it works properly!
So is it reasonable to use 3 videoOutputs ?
So is it reasonable to put them in different threads ?
Why does videoSource have to capture one frame before any attempt is made to declare or use a videoOutput ?
I hope you can help.
thanks
JC
DEBUG:(general_timer) ** Starting general_timer()
DEBUG:(get_camera_frame) ** Starting get_camera_frame()
DEBUG:(show_image_in_window) ** Starting show_image_in_window()
DEBUG:(analyse_images) ** Starting
DEBUG:(main) after launching all threads
DEBUG:(main) waiting for thread start
segNet -- loading segmentation network model from:
-- prototxt: (null)
-- model: /home/jc/jcCode/trained_models/jc_floor_alone_640x480/fcn_resnet18.onnx
-- labels: /home/jc/jcCode/trained_models/jc_floor_alone_640x480/classes.txt
-- colors: /home/jc/jcCode/trained_models/jc_floor_alone_640x480/colors.txt
-- input_blob 'input_0'
-- output_blob 'output_0'
-- batch_size 1
[TRT] TensorRT version 8.0.1
[TRT] Could not register plugin creator - ::FlattenConcat_TRT version 1
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] [MemUsageChange] Init CUDA: CPU +198, GPU -1, now: CPU 234, GPU 3847 (MiB)
[TRT] loading network plan from engine cache... /home/jc/jcCode/trained_models/jc_floor_alone_640x480/fcn_resnet18.onnx.1.1.8001.GPU.FP16.engine
[TRT] device GPU, loaded /home/jc/jcCode/trained_models/jc_floor_alone_640x480/fcn_resnet18.onnx
[TRT] [MemUsageChange] Init CUDA: CPU +0, GPU +0, now: CPU 291, GPU 3855 (MiB)
[TRT] Loaded engine size: 57 MB
[TRT] [MemUsageSnapshot] deserializeCudaEngine begin: CPU 291 MiB, GPU 3855 MiB
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +158, GPU -94, now: CPU 449, GPU 3757 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +241, GPU -64, now: CPU 690, GPU 3693 (MiB)
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 690, GPU 3694 (MiB)
[TRT] [MemUsageSnapshot] deserializeCudaEngine end: CPU 690 MiB, GPU 3694 MiB
[TRT] [MemUsageSnapshot] ExecutionContext creation begin: CPU 690 MiB, GPU 3685 MiB
[TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU -3, now: CPU 690, GPU 3682 (MiB)
[TRT] [MemUsageChange] Init cuDNN: CPU +0, GPU +0, now: CPU 690, GPU 3682 (MiB)
[TRT] [MemUsageSnapshot] ExecutionContext creation end: CPU 690 MiB, GPU 3663 MiB
[TRT]
[TRT] CUDA engine context initialized on device GPU:
[TRT] -- layers 25
[TRT] -- maxBatchSize 1
[TRT] -- deviceMemory 14745600
[TRT] -- bindings 2
[TRT] binding 0
-- index 0
-- name 'input_0'
-- type FP32
-- in/out INPUT
-- # dims 4
-- dim #0 1
-- dim #1 3
-- dim #2 480
-- dim #3 640
[TRT] binding 1
-- index 1
-- name 'output_0'
-- type FP32
-- in/out OUTPUT
-- # dims 4
-- dim #0 1
-- dim #1 7
-- dim #2 15
-- dim #3 20
[TRT]
[TRT]
[TRT] device GPU, /home/jc/jcCode/trained_models/jc_floor_alone_640x480/fcn_resnet18.onnx initialized.
[gstreamer] opening gstCamera for streaming, transitioning pipeline to GST_STATE_PLAYING
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 5
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120.000005
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
DEBUG:(analyse_images) Segnet model loaded and buffers allocated
DEBUG:(get_camera_frame) camera is live
DEBUG:(analyse_images) Network Num classes = 7
DEBUG:(analyse_images) Network grid width = 20 height = 15
DEBUG:(show_image_in_window) after opening outvid = display
DEBUG:(get_camera_frame) video file_name=/media/jc/ROBO-USB/Robo_Video_trace/robo_wander_base_20220727-130907_0000.mp4
DEBUG:(analyse_images) video file_name=/media/jc/ROBO-USB/Robo_Video_trace/robo_wander_dir_20220727-130908_0000.mp4
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/python/bindings/PyCUDA.cpp:1102
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
DEBUG:(analyse_images) after opening outvid = vector mp4
NvMMLiteBlockCreate : Block : BlockType = 4
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/codec/gstBufferManager.cpp:319
[gstreamer] gstDecoder -- failed to retrieve next image buffer
H264: Profile = 66, Level = 40
NVMEDIA_ENC: bBlitMode is set to TRUE
Exception in thread Thread-6:
File "/usr/lib/python3.6/threading.py", line 916, in _bootstrap_inner
self.run()
File "/usr/lib/python3.6/threading.py", line 864, in run
self._target(*self._args, **self._kwargs)
File "/home/jc/jcCode/car_controller_P6_0v083/car_controller_P6_images.py", line 162, in get_camera_frame
image = camera.Capture()
Exception: jetson.utils -- videoSource failed to capture image
CONSUMER: Done Success
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
[cuda] /home/jc/SW_Components2021/jetson-inference/build/aarch64/include/jetson-utils/RingBuffer.inl:119
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/cuda/cudaFont.cu:98
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/cuda/cudaFont.cu:106
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/cuda/cudaFont.cu:114
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/python/bindings/PyCUDA.cpp:69
Exception in thread Thread-8:
self.run()
File "/home/jc/jcCode/car_controller_P6_0v083/car_controller_P6_images.py", line 507, in analyse_images
jetson.utils.cudaMemcpy(TempCudaImageToUse, rwsg.G_CudaImageToUse)
TypeError: jetson.utils -- cudaMemcpy() failed to copy memory
[TRT] [defaultAllocator.cpp::free::85] Error Code 1: Cuda Runtime (unspecified launch failure)
DEBUG:(main) all threads report 'running'
Exception in thread Thread-7:
self.run()
File "/home/jc/jcCode/car_controller_P6_0v083/car_controller_P6_images.py", line 305, in show_image_in_window
jetson.utils.cudaMemcpy(TempCudaImageToUse, rwsg.G_CudaImageToUse) # 0v81
[cuda] /home/jc/SW_Components2021/jetson-inference/utils/display/glTexture.cpp:246
DEBUG:(messaging.initialisation) after Mqtt client loop start
INFO:(main) Starting Main Loop at time=13:09:30
DEBUG:Connected With Result Code 0
DEBUG:(do_subscribe) after client.subscribe
DEBUG:(general_timer) rwsg.G_event_10units triggered at time=13:09:40
INFO:(things_to_do_every_10sec) Main Loop count=4579 Image count=1 (0fps) analysed_image_count=1 image_in_window_count=3 at increment time=13:09:40 thats 468 loops/sec
INFO:(main) Main Loop count=5000 Image count=1 (0fps) analysed_image_count=1 image_in_window_count=3 at increment time=13:09:41 thats 467 loops/sec
DEBUG:(general_timer) rwsg.G_event_10units triggered at time=13:09:50
INFO:(things_to_do_every_10sec) Main Loop count=9337 Image count=1 (0fps) analysed_image_count=1 image_in_window_count=3 at increment time=13:09:50 thats 469 loops/sec
DEBUG: regular status check. G_autowander_mode =False
INFO:(main) Main Loop count=10000 Image count=1 (0fps) analysed_image_count=1 image_in_window_count=3 at increment time=13:09:51 thats 469 loops/sec
DEBUG:(general_timer) rwsg.G_event_10units triggered at time=13:10:00
INFO:(things_to_do_every_10sec) Main Loop count=14117 Image count=1 (0fps) analysed_image_count=1 image_in_window_count=3 at increment time=13:10:00 thats 470 loops/sec
INFO:(main) Main Loop count=15000 Image count=1 (0fps) analysed_image_count=1 image_in_window_count=3 at increment time=13:10:02 thats 471 loops/sec
