all of the above • DeepStream Version
5.0 • JetPack Version (valid for Jetson only)
4.4 • TensorRT Version
7.1 • NVIDIA GPU Driver Version (valid for GPU only)
440.64.00
In my pipeline I’m attaching batch level user metadata to batch_meta->batch_user_meta_list
I’ve attached copy and release functions for the metadata, as well as a custom type. My question is: what is responsible for calling the release function? Is it the broker element, is this somehow handled at the end of the pipeline by gstreamer, or something else?
I want to use a custom broker element suitable to my purpose (call a python callback with my string payload), and I want to make sure I don’t leak memory.
Hi
It should be handled when pipeline running into end.
you can refer to sample deepstream-infer-tensor-meta-test for how to use copy/release function.
Are you sure that’s the right example? Unless the search function is failing me, I don’t see any use of a custom release function in that file.
I attached such functions to the buffer like in the custom metadata example (deepstream_user_metadata_app.c). in that example something in the pipeline calls it, but what exactly isn’t specified. Are you saying this happens automatically at the end of the pipeline?
