What is the actural spec for Orin MIPI CPHY?
Hi,Jerry
Is there any new progress?Thank you
Hi,Jerry, ShaneCCC
hello 541449841,
we’ve already have arrange resources to investigate this internally.
it looks like BW is not available anymore.
would like to double confirm…
do you still seeing this with below commands to boost all the clocks, especially the commands for setting the VI clock to max?
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
yes,I have tried the above command。
Orin will still crash.
Thank you so much for your support
Hi,Is there any new progress?Thank you
