What is the best way for drawing some alarm zones in Deepstream?
Hi everyone,
I am trying to develop Deepstream application and set some alarms to control arduino by sending signals. Now I am using this code for drawing alarm zones
    # Draw alarm zones
    display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
    for zone in u_data:
        rect_params = display_meta.rect_params[zone['id']]
        rect_params.left = zone['left']
        rect_params.top = zone['top']
        rect_params.width = zone['width']
        rect_params.height = zone['height']
        rect_params.border_width = 3
        rect_params.border_color.set(1.0, 0.0, 0.0, 1.0)  # Red
    display_meta.num_rects = len(u_data)
    pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
But I am wondering if can I use OpenCV to trigger my alarms instead of using probes? Because what I am afraid is reduce the performance of system unnecessarily because I wont display camera output from jetson device always.
Thank you for advance
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6
• JetPack Version (valid for Jetson only) 4
• TensorRT Version 8
The way you’re using can get the best performace. It used GPU to draw the bbox. But if you want to use that with OpenCV, you have to copy the image from gpu to cpu. After drawing that, you have to copy that from the cpu to gpu again. This can significantly degrade the performance.
