What is the best way to migrate from 6.1 to 6.3 Deepstream ? Also Is there any way I can see the compression of each plugin files and code?
• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 6.1 and 6.3 ( 6.1 - base and 6.3 sample)
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) - 525
• Issue Type( questions, new requirements, bugs) - 11.6 and 12.0
I wanted to check difference between the 6.1 and 6. 3 config files, Also wanted to know which properties are depreciated and which are being added as new one.
I have added a smaple of tracker config file 6.3 vs 6. for reference .
Also If I want to migrate my app from 6.1-basse image to 6.3 -sample image what is optimal way to do it. ?
The release note may help you https://docs.nvidia.com/metropolis/deepstream/DeepStream_6.3_Release_Notes.pdf
The historical documents are also useful. DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
The best way is to use the configuration files in /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/
