Hey,
we are currently creating config for our custom board and found in p3768-0000+p3767-0000.conf (Config for Orin SOM on Orin Devkit)
BPFDTB_FILE="tegra234-bpmp-3767-0003-3509-a02.dtb";
DTB_FILE="tegra234-p3767-0003-p3768-0000-a0.dtb";
The p3509-a02 is the Xavier NX Devkit Board.
What is the BPFDTB_FILE? Is it some kind of fallback DTB so that a flashed board can boot in Xavier and Orin Devkits?
Bpmp dtp is for the bpmp to use. Not for fallback.
This is not public source.
Sorry that I do not know the terminology.
What is the bpmp?
How do we create the correct BPFDTB file for our custom board?
I am also confused that the p3768 board config uses the file of the p3509.
It is Boot and Power Management (BPMP) firmware, which runs on a separate BPMP processor. Mostly handle clock/thermal and power management.
Basically end users should not touch this part. Please just use the default one we provided in BSP.
If I remember correctly, both p3509 and p3766 carrier board all use same bpmp dtb.
Okay thanks, will do that then!
system
Closed
8
