By following the “Getting Started Guide”,
The command to use the inference on a classification model is:
tlt-infer classification [-h] [-m MODEL] [-i IMAGE] [-d IMAGE_DIR] [-b BATCH_SIZE] [-k KEY] [-cm CLASSMAP][-v]
-cm CLASSMAP, --class_map CLASSMAP: The json file that specifies the class index and label mapping.
What format should this CLASSMAP json file be?
