Hi WayneWWW,
For PCIe/Ethernet drivers, I didn’t see anything that immediately jumped out at me. Here is the output from minicom since the start of u-boot:
U-Boot 2014.10-rc2-00001-g5e56064-dirty (Aug 29 2017 - 19:29:14)
TEGRA124
Board: NVIDIA Jetson TK1
I2C: ready
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x12000000-0x12010000
tegra-pcie: non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie: prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 4x1, 1x1 configuration
tegra-pcie: probing port 0, using 4 lanes
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
tegra-pcie: probing port 1, using 1 lanes
tegra-pcie: link 1 down, retrying
tegra-pcie: link 1 down, ignoring
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
6372 bytes read in 139 ms (43.9 KiB/s)
Jetson-TK1 eMMC boot options
1: zImage
2: zImage-TFLOP
3: zImage-SPISlave
4: zImage-SPIEnabled
5: zImage-Xen
6: zImage-IcacheDisabled
7: zImage-DVFSDisabled
8: zImage-DVFSAndTempDisabled
Enter choice: 2: zImage-TFLOP
Retrieving file: /boot/zImage-TFLOP
6039488 bytes read in 280 ms (20.6 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M ot
Retrieving file: /boot/tegra124-tflop-pm375-000-c00-00.dtb
59622 bytes read in 127 ms (458 KiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x5c27c0 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 820118e5
get_board_serial: I2C read of bus 1 chip 86 addr 4 failed!
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40+g71cc3bf (austin@austin-VirtualBox) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #7 SMP PREEMPT Wed Aug 30 13:55:41 PDT 2017
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: jetson-tk1, model: NVIDIA Tegra124 PM375, serial: 0
[ 0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[ 0.000000] Found tsec, start=0xf4900000 size=2000000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f8500000 - f96fffff
[ 0.000000] 2nd Framebuffer: f9700000 - fdefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: f4900000 - f68fffff
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm/boot/dts/tegra124-tflop-pm375-000-c00-00.dts
[ 0.000000] Tegra12: CPU Speedo value 2255, Soc Speedo value 2201, Gpu Speedo value 2005
[ 0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[ 0.000000] Lowering se maximum rate from 600000000 to 480000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 480000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1df3000 s15168 r8192 d13504 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 490768
[ 0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x0t
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1923MB = 1923MB total
[ 0.000000] Memory: 1920996k/1920996k available, 142364k reserved, 1190908K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b0f198 (11293 kB)
[ 0.000000] .init : 0xc0b10000 - 0xc0b8cb40 ( 499 kB)
[ 0.000000] .data : 0xc0b8e000 - 0xc0cedfa8 (1408 kB)
[ 0.000000] .bss : 0xc0cedfa8 - 0xc0d88f4c ( 620 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.002889] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.002944] pid_max: default: 32768 minimum: 301
[ 0.003250] Mount-cache hash table entries: 512
[ 0.025426] Initializing cgroup subsys debug
[ 0.025464] Initializing cgroup subsys freezer
[ 0.025561] CPU: Testing write buffer coherency: ok
[ 0.025623] ftrace: allocating 30700 entries in 60 pages
[ 0.064497] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.064539] Setting up static identity map for 0xc07f77e8 - 0xc07f7894
[ 0.068523] ftrace: Allocated trace_printk buffers
[ 0.076181] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.079213] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.082240] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.082441] Brought up 4 CPUs
[ 0.082500] SMP: Total of 4 processors activated.
[ 0.082516] CPU: All CPU(s) started in SVC mode.
[ 0.083493] devtmpfs: initialized
[ 0.092339] pinctrl core: initialized pinctrl subsystem
[ 0.092695] regulator-dummy: no parameters
[ 0.093417] NET: Registered protocol family 16
[ 0.095772] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.097048] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.098070] console [pstore-1] enabled
[ 0.098107] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[ 0.098471] cpuidle: using governor ladder
[ 0.098493] cpuidle: using governor menu
[ 0.102173] ardbeg_camera_auxdata: update camera lookup table.
[ 0.110510] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.111033] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.117639] Wake16 for irq=34
[ 0.120002] Wake58 for irq=81
[ 0.120049] Wake41 for irq=129
[ 0.120067] Wake43 for irq=129
[ 0.120111] Wake40 for irq=53
[ 0.120127] Wake42 for irq=53
[ 0.124266] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x42:0x44:0x00
[ 0.124363] board_info: id:sku:fab:major:minor = 0x0177:0x0000:0x42:0x44:0x00
[ 0.124448] Selecting UARTD as the debug console
[ 0.124491] The debug console clock name is uartd
[ 0.124909] ardbeg_modem_init: modem_id = 0
[ 0.127540] Clear bootloader IO dpd settings
[ 0.127781] Loading jetson TK1 EMC tables.
[ 0.128021] tegra: pll_m is selected as scalable EMC clock source
[ 0.128064] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.128093] tegra: validated EMC DFS table
[ 0.128220] ardbeg_edp_init: CPU regulator 12500 mA
[ 0.372311] ardbeg_edp_init: GPU regulator 11400 mA
[ 0.373248] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.373269] swapper/0 isomgr_init(): max_iso_bw=7392000KB[ 0.373609] ardbeg_touch_init init raydium touch
[ 0.373754] Raydium - touch platform_id : 8
[ 0.456563] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[ 0.459867] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[ 0.464871] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[ 0.468165] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[ 0.468591] FUSE: cp_rev 0 ft_rev 0
[ 0.468762] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.469171] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.469201] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.469499] mc-err: Started MC error interface!
[ 0.479760] bio: create slab <bio-0> at 0
[ 0.481616] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[ 0.481651] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[ 0.481780] vdd-ac-bat: 8400 mV
[ 0.481912] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.481945] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.482089] vdd-3v3-aon: 3300 mV
[ 0.482237] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[ 0.482269] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[ 0.482300] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[ 0.482335] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[ 0.482364] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[ 0.482394] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[ 0.482424] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[ 0.482454] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[ 0.482484] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[ 0.482513] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[ 0.482642] reg-3v3-supply: 3300 mV
[ 0.484254] vgaarb: loaded
[ 0.484855] SCSI subsystem initialized
[ 0.485247] usbcore: registered new interface driver usbfs
[ 0.485311] usbcore: registered new interface driver hub
[ 0.485423] usbcore: registered new device driver usb
[ 0.488247] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[ 0.488276] as3722 4-0040: Final OTP version 1V21
[ 0.493468] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.493666] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.493724] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.493775] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.493806] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.493837] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.493867] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.493922] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.493953] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.493983] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.494013] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.494043] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.494073] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.494103] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.494187] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.494220] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.494250] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.494279] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.494312] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.494344] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.494374] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.494404] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.494434] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.494464] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.494494] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.494525] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.494554] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.494608] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.494638] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.494690] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.494720] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.494750] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.494780] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.494809] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.494839] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.494868] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.494898] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.494928] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.494983] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.495013] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.495101] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.495131] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.495179] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.495233] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.495282] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.495312] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.495342] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.495395] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.495426] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.495481] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.495534] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.495565] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.495637] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.495668] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.495697] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.496604] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.497374] vdd-core: applied init 1150000uV constraint
[ 0.497971] vdd-core: 700 <--> 1350 mV at 1150 mV 3500 mA
[ 0.499161] vddio-ddr: at 1350 mV
[ 0.499493] as3722-sd3: no parameters
[ 0.500066] avdd-pll-pex: 1050 mV
[ 0.501258] vdd-1v8: at 1800 mV
[ 0.501591] vdd-gpu: applied init 1000000uV constraint
[ 0.502463] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.502956] avdd-pll: at 1050 mV at 300 mA
[ 0.504219] vdd-cam: 1800 mV at 150 mA
[ 0.504914] avdd-dsi-csi: at 1200 mV at 150 mA
[ 0.506132] vdd-rtc: 800 mV at 150 mA
[ 0.506614] avdd-cam: 2800 mV at 150 mA
[ 0.507095] vdd-1v2-cam: 1175 mV at 150 mA
[ 0.507473] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[ 0.507963] vdd-1v1-cam: 1275 mV at 150 mA
[ 0.508922] avdd-spi: 3300 mV at 150 mA
[ 0.509416] vdd-2v7-cam: 2800 mV at 150 mA
[ 0.509918] vpp-fuse: 1800 mV at 150 mA
[ 0.510975] Linux video capture interface: v2.00
[ 0.512015] Advanced Linux Sound Architecture Driver Initialized.
[ 0.512475] ardbeg_wifi_power: 1
[ 0.613369] usb0-vbus: 5000 mV
[ 0.613663] usb1-usb2-vbus: 5000 mV
[ 0.613943] vdd-hdmi: 5000 mV
[ 0.614240] avdd-hdmi-pll: 3300 mV
[ 0.614288] avdd-hdmi-pll: supplied by avdd-pll-pex
[ 0.614453] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[ 0.614604] vdd-lcd-bl: 3300 mV
[ 0.614779] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[ 0.614927] vdd-lcd-bl-en: 5000 mV
[ 0.615097] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[ 0.615213] reg-5v0-supply: 5000 mV
[ 0.615373] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[ 0.615406] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[ 0.615436] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[ 0.615483] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[ 0.615514] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[ 0.615544] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[ 0.615574] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[ 0.615604] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[ 0.615634] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[ 0.615772] reg-1v8-supply: 1800 mV
[ 0.616067] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[ 0.616250] reg-dcdc-1v2: 1200 mV
[ 0.616420] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[ 0.616453] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[ 0.617006] as3722-gpio2-supply: 3300 mV
[ 0.617221] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[ 0.617728] as3722-gpio4-supply: 3300 mV
[ 0.618011] sdmmc-en-supply: 3300 mV
[ 0.618284] vdd-cdc-1v2-aud: 1200 mV
[ 0.618436] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[ 0.618470] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[ 0.618501] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[ 0.618621] reg-aon-1v8: 1800 mV
[ 0.618782] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[ 0.618899] reg-aon-1v2: 1200 mV
[ 0.621860] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is disconnected
[ 0.625178] tegra: started io power detection dynamic control
[ 0.625203] tegra: NO_IO_POWER setting 0x0
[ 0.625249] Switching to clocksource arch_sys_counter
[ 0.646942] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.647125] nvmap_page_pool_init: Total MB RAM: 1891
[ 0.647148] nvmap_page_pool_init: nvmap page pool size: 60543 pages (236 MB)
[ 0.647316] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.647501] iram: dma coherent mem declare 0x40001000,258048
[ 0.648351] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.648511] nvmap:inner cache maint threshold=2097152
[ 0.657570] Wake39 for irq=52
[ 0.657666] tegra-otg tegra-otg: otg transceiver registered
[ 0.658012] NET: Registered protocol family 2
[ 0.658694] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.658898] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.659089] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.659149] TCP: reno registered
[ 0.659172] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.659228] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.659581] NET: Registered protocol family 1
[ 0.659964] RPC: Registered named UNIX socket transport module.
[ 0.659988] RPC: Registered udp transport module.
[ 0.660007] RPC: Registered tcp transport module.
[ 0.660026] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.660325] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.665755] host1x host1x: initialized
[ 0.667006] CPU PMU: probing PMU on CPU 0
[ 0.667040] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.667667] tegra_throttle : init passed
[ 0.667780] Tegra cpuquiet initialized: disabled
[ 0.667912] cpu-tegra: init EDP limit: 2065 MHz
[ 0.668871] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.669232] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.669481] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.669711] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.671217] bounce pool size: 64 pages
[ 0.672647] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.672926] NTFS driver 2.1.30 [Flags: R/O].
[ 0.673190] fuse init (API version 7.22)
[ 0.673431] msgmni has been set to 1457
[ 0.674774] io scheduler noop registered (default)
[ 0.876183] PCIE: port 0: link down, retrying
[ 1.076350] PCIE: port 0: link down, retrying
[ 1.276490] PCIE: port 0: link down, retrying
[ 1.276509] PCIE: port 0: link down, ignoring
[ 1.281667] PCI host bridge to bus 0000:00
[ 1.281695] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 1.281724] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 1.281753] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.281778] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.284843] PCI: bus0: Fast back to back transfers disabled
[ 1.284869] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.287859] PCI: bus1: Fast back to back transfers disabled
[ 1.288181] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.288209] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.288474] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 1.288506] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff 64bit pref]
[ 1.288537] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.288567] pci 0000:01:00.0: BAR 4: assigned [mem 0x12100000-0x12103fff 64bit pref]
[ 1.288613] pci 0000:01:00.0: BAR 2: assigned [mem 0x32100000-0x32100fff 64bit]
[ 1.288656] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.288685] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 1.288710] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.288737] pcieport 0000:00:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 1.288766] pcieport 0000:00:00.0: bridge window [mem 0x12100000-0x121fffff 64bit pref]
[ 1.288806] PCIE: No Link speed change happened
[ 1.289366] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[ 1.289470] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[ 1.290351] tsec tsec: initialized
[ 1.291802] isp isp.0: initialized
[ 1.292759] isp isp.1: initialized
[ 1.294287] falcon vic03.0: initialized
[ 1.295491] falcon msenc: initialized
[ 1.296261] tegradc tegradc.0: DSI: HS clock rate is 464500
[ 1.297530] p,wuxga-10-1 panel dt support not available
[ 1.577209] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[ 1.666476] tegradc tegradc.0: DSI pad calibration done
[ 1.673616] tegradc tegradc.0: probed
[ 1.674078] tegradc tegradc.0: fb registered
[ 1.674103] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[ 1.679943] gpio wake4 for gpio=111
[ 2.679337] tegra-i2c tegra12-i2c.3: --- register dump for debugging ----
[ 2.679367] tegra-i2c tegra12-i2c.3: I2C_CNFG - 0x2c00
[ 2.679391] tegra-i2c tegra12-i2c.3: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 2.679416] tegra-i2c tegra12-i2c.3: I2C_FIFO_CONTROL - 0xe0
[ 2.679439] tegra-i2c tegra12-i2c.3: I2C_FIFO_STATUS - 0x800040
[ 2.679462] tegra-i2c tegra12-i2c.3: I2C_INT_MASK - 0xed
[ 2.679484] tegra-i2c tegra12-i2c.3: I2C_INT_STATUS - 0x0
[ 2.679506] tegra-i2c tegra12-i2c.3: msg->len - 1
[ 2.679527] tegra-i2c tegra12-i2c.3: is_msg_write - 1
[ 2.679548] tegra-i2c tegra12-i2c.3: next_msg->len - 128
[ 2.679570] tegra-i2c tegra12-i2c.3: is_next_msg_write - 0
[ 2.679592] tegra-i2c tegra12-i2c.3: buf_remaining - 128
[ 2.679619] tegra-i2c tegra12-i2c.3: i2c transfer timed out, addr 0x0050, data 0x00
[ 2.680533] tegradc tegradc.1: probed
[ 2.685141] Console: switching to colour frame buffer device 80x30
[ 2.689739] tegradc tegradc.1: fb registered
[ 2.691221] hdmi_state_machine_worker (tid edb06080): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 2.694147] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 2.697485] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 2.701443] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.704294] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[ 2.736351] hdmi_state_machine_worker (tid edb06080): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 2.736355] hdmi_disable_l: audio_switch 0
[ 2.736358] hdmi_disable_l: hpd_switch 0
[ 2.736363] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 2.746348] hdmi_state_machine_worker (tid edb06080): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 2.746352] hdmi_disable_l: audio_switch 0
[ 2.746354] hdmi_disable_l: hpd_switch 0
[ 2.746359] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.919688] console [ttyS0] enabled
[ 5.925409] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[ 5.936836] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 5.948547] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 5.965375] loop: module loaded
[ 5.970900] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[ 5.982483] gpio wake35 for gpio=70
[ 5.988241] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 5.996773] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 6.010983] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 6.026093] tegra_profiler: Branch: Dev
[ 6.032276] tegra_profiler: Version: 1.103
[ 6.038649] tegra_profiler: Samples version: 34
[ 6.045417] tegra_profiler: IO version: 18
[ 6.051661] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[ 6.059248] tegra_profiler: auth: init
[ 6.065418] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[ 6.075287] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 6.088587] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[ 6.102380] scsi0 : tegra-sata
[ 6.107788] scsi1 : tegra-sata
[ 6.112987] ata1: SATA max UDMA/133 irq 55
[ 6.118979] ata2: DUMMY
[ 6.124999] tun: Universal TUN/TAP device driver, 1.6
[ 6.131861] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 6.140107] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 6.150079] r8169 0000:01:00.0 eth0: RTL8168g/8111g at 0xf0000000, 00:00:00:00:00:00, XID 0c000800 IRQ 641
[ 6.163428] r8169 0000:01:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 6.175760] usbcore: registered new interface driver asix
[ 6.183053] usbcore: registered new interface driver ax88179_178a
[ 6.190988] usbcore: registered new interface driver cdc_ether
[ 6.198628] usbcore: registered new interface driver smsc95xx
[ 6.206139] usbcore: registered new interface driver cdc_subset
[ 6.213877] usbcore: registered new interface driver cdc_ncm
[ 6.221256] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.229700] tegra USB phy - inst[1] platform info:
[ 6.236256] port_otg: no
[ 6.240462] has_hostpc: yes
[ 6.244868] phy_interface: USB_PHY_INTF_UTMI
[ 6.250724] op_mode: TEGRA_USB_OPMODE_HOST
[ 6.256368] qc2_voltage: 0
[ 6.260523] vbus_gpio: -1
[ 6.264579] hot_plug: disabled
[ 6.269092] remote_wakeup: enabled
[ 6.275421] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 6.282934] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 6.293608] Wake40 for irq=53
[ 6.298039] Wake42 for irq=53
[ 6.302464] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 6.315343] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[ 6.322728] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.330884] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.340738] usb usb1: Product: Tegra EHCI Host Controller
[ 6.347613] usb usb1: Manufacturer: Linux 3.10.40+g71cc3bf ehci_hcd
[ 6.355384] usb usb1: SerialNumber: tegra-ehci.1
[ 6.361983] hub 1-0:1.0: USB hub found
[ 6.367300] hub 1-0:1.0: 1 port detected
[ 6.373048] tegra USB phy - inst[2] platform info:
[ 6.379326] port_otg: no
[ 6.383315] has_hostpc: yes
[ 6.387551] phy_interface: USB_PHY_INTF_UTMI
[ 6.393324] op_mode: TEGRA_USB_OPMODE_HOST
[ 6.398889] qc2_voltage: 0
[ 6.403036] vbus_gpio: -1
[ 6.407094] hot_plug: disabled
[ 6.411593] remote_wakeup: enabled
[ 6.417875] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 6.425320] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 6.428364] ata1: SATA link down (SStatus 0 SControl 300)
[ 6.442788] Wake41 for irq=129
[ 6.447368] Wake43 for irq=129
[ 6.451921] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 6.465341] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[ 6.472871] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.481209] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.491373] usb usb2: Product: Tegra EHCI Host Controller
[ 6.498340] usb usb2: Manufacturer: Linux 3.10.40+g71cc3bf ehci_hcd
[ 6.506135] usb usb2: SerialNumber: tegra-ehci.2
[ 6.512735] hub 2-0:1.0: USB hub found
[ 6.518036] hub 2-0:1.0: 1 port detected
[ 6.523774] ehci-pci: EHCI PCI platform driver
[ 6.529974] tegra_xusb_read_usb_calib: usb_calib0 = 0x0285838b
[ 6.537620] usbcore: registered new interface driver usb-storage
[ 6.545338] usbcore: registered new interface driver usbserial
[ 6.552780] usbcore: registered new interface driver option
[ 6.559942] usbserial: USB Serial support registered for GSM modem (1-port)
[ 6.568620] usbcore: registered new interface driver pl2303
[ 6.575863] usbserial: USB Serial support registered for pl2303
[ 6.583506] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 6.594291] tegra USB phy - inst[0] platform info:
[ 6.600777] port_otg: yes
[ 6.605059] has_hostpc: yes
[ 6.609453] phy_interface: USB_PHY_INTF_UTMI
[ 6.615389] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 6.621292] qc2_voltage: 0
[ 6.625666] vbus_pmu_irq: 0
[ 6.630026] vbus_gpio: -1
[ 6.634172] charging: enabled
[ 6.638598] remote_wakeup: disabled
[ 6.646211] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 6.661624] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[ 6.669964] as3722-rtc as3722-rtc.1: RTC interrupt 449
[ 6.679382] i2c /dev entries driver
[ 6.685476] virtual_init
[ 6.691288] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[ 6.699444] tegra_dtv_probe: probing dtv.
[ 6.705118] setup_stream: bufsize = 4096, bufnum = 4
[ 6.710265] ar0832_init: ++
[ 6.716718] i2c-core: driver [max77387] using legacy suspend method
[ 6.724625] i2c-core: driver [max77387] using legacy resume method
[ 6.732490] i2c-core: driver [as364x] using legacy suspend method
[ 6.740142] i2c-core: driver [as364x] using legacy resume method
[ 6.747771] [IMX135] sensor driver loading
[ 6.753406] [IMX179] sensor driver loading
[ 6.758992] [IMX185] sensor driver loading
[ 6.764551] [imx132] sensor driver loading
[ 6.770058] [AR0330] sensor driver loading
[ 6.775561] [ar0261] sensor driver loading
[ 6.781017] [AR1335] sensor driver loading
[ 6.786448] [ov4689] sensor driver loading
[ 6.792598] usbcore: registered new interface driver uvcvideo
[ 6.799738] USB Video Class driver (1.1.1)
[ 6.805972] zram: Created 1 device(s) ...
[ 6.811335] otg state changed: SUSPEND --> PERIPHERAL
[ 6.818814] tegra_wdt tegra_wdt.0: last reset is due to power on reset
[ 6.826816] WDT heartbeat enabled on probe
[ 6.832318] tegra_wdt_probe done
[ 6.837120] sdhci: Secure Digital Host Controller Interface driver
[ 6.844676] sdhci: Copyright(c) Pierre Ossman
[ 6.850416] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.857903] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[ 6.871590] sdhci-tegra sdhci-tegra.3: Speedo value 2201
[ 6.878301] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 6.890746] mmc0: no vqmmc regulator found
[ 6.896343] mmc0: no vmmc regulator found
[ 6.901787] mmc0: Invalid maximum block size, assuming 512 bytes
[ 6.909339] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[ 6.944346] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 6.957581] sdhci-tegra sdhci-tegra.2: Speedo value 2201
[ 6.964854] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[ 6.980345] mmc1: no vqmmc regulator found
[ 6.986522] mmc1: no vmmc regulator found
[ 6.992528] mmc1: Invalid maximum block size, assuming 512 bytes
[ 7.000627] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found[ 7.022581] mmc0: BKOPS_EN bit is not set
[ 7.034061] sdhci-tegra sdhci-tegra.3: Found T2T coeffs data
[ 7.036354] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 7.053105] sdhci-tegra sdhci-tegra.3: 200MHz tap hole coeffs found
[ 7.053203] gpio wake56 for gpio=170
[ 7.056642] tegra-se tegra12-se: tegra_se_probe: complete
[ 7.059096] usbcore: registered new interface driver usbhid
[ 7.059098] usbhid: USB HID core driver
[ 7.059545] tegra-hier-ictlr tegra-hier-ictlr: probed
[ 7.169967] usbcore: registered new interface driver snd-usb-audio
[ 7.178703] MAX98090 driver built on Aug 28 2017 at 18:47:13
[ 7.187076] tegra_offload_platform probe successfull.
[ 7.194906] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[ 7.458067] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.468739] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.487430] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.495907] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.504288] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.512539] rt5639 0-001c: read 0xfd=0xffffffff
[ 7.518908] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.527300] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.535605] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.543811] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.551942] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.559977] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.567919] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.575867] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.583737] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.591537] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.599277] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.606958] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.614587] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.622178] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.629688] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.637124] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.640409] **********Auto tuning windows*************
[ 7.640413] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 7.640419] win[0]: 0(0) - 72(1)
[ 7.640423] win[1]: 78(0) - 155(1)
[ 7.640427] win[2]: 161(0) - 239(1)
[ 7.640431] win[3]: 245(0) - 255(1)
[ 7.640434] ***************************************
[ 7.640463] ********tuning windows after inserting holes*****
[ 7.640465] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 7.640470] win[0]:-5(0) - 43(2)
[ 7.640473] win[1]:45(2) - 72(1)
[ 7.640477] win[2]:78(0) - 126(2)
[ 7.640480] win[3]:128(2) - 155(1)
[ 7.640483] win[4]:161(0) - 209(2)
[ 7.640487] win[5]:211(2) - 239(1)
[ 7.640490] win[6]:245(0) - 255(1)
[ 7.640492] ***********************************************
[ 7.640496] **********Tuning values*********
[ 7.640499] **estimated values**
[ 7.640503] T2T_Vmax 58, T2T_Vmin 82, 1'st_hole_Vmax 46, UI_Vmax 86
[ 7.640505] **Calculated values**
[ 7.640509] T2T_Vmax 60, 1'st_hole_Vmax 44, UI_Vmax 83
[ 7.640512] T2T_Vmin 60, 1'st_hole_Vmin 44, UI_Vmin 83
[ 7.640514] ***********************************
[ 7.640524] ***********final tuning windows**********
[ 7.640528] win[0]: 11 - 34
[ 7.640531] win[1]: 55 - 56
[ 7.640535] win[2]: 94 - 112
[ 7.640538] win[3]: 143 - 139
[ 7.640541] win[4]: 177 - 189
[ 7.640544] win[5]: 232 - 223
[ 7.640547] win[6]: 255 - 239
[ 7.640549] ********************************
[ 7.640553] best tap win - (11-34), best tap value 23 prev_best_tap 0
[ 7.812043] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.819764] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.827453] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.835120] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.842771] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.850439] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.858068] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.865659] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.873198] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.880712] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.888165] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.895535] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.902890] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.910209] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.917485] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.924715] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.931905] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.939091] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.946261] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.953470] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.960625] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.967787] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.974953] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.982059] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.989109] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 7.996093] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.003066] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.010040] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.017038] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.023924] rt5639 0-001c: Failed to set private addr: -121
[ 8.030015] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.037161] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x1c
[ 8.048768] rt5639 0-001c: ASoC: mux INR Mux has no paths
[ 8.054786] rt5639 0-001c: ASoC: mux INL Mux has no paths
[ 8.061423] gpio wake49 for gpio=143
[ 8.065755] rt5639 0-001c: rt5639_headset_detect jack_type = 1
[ 8.072638] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 8.082879] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-spdif mapping ok
[ 8.093322] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> tegra30-i2s.3 mapping ok
[ 8.104185] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> dit-hifi mapping ok
[ 8.115178] tegra-snd-rt5639 tegra-snd-rt5639.0: dit-hifi <-> dit-hifi mapping ok
[ 8.126243] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 8.137123] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 8.148297] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 8.161933] compress asoc: snd-soc-dummy-dai <-> tegra-offload-compr mapping ok
[ 8.174120] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream playback
[ 8.184366] **********Auto tuning windows*************
[ 8.184369] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 8.184375] win[0]: 0(0) - 72(1)
[ 8.184381] win[1]: 78(0) - 155(1)
[ 8.184385] win[2]: 161(0) - 239(1)
[ 8.184390] win[3]: 245(0) - 255(1)
[ 8.184393] ***************************************
[ 8.184402] ********tuning windows after inserting holes*****
[ 8.184404] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[ 8.184409] win[0]:-5(0) - 43(2)
[ 8.184413] win[1]:45(2) - 72(1)
[ 8.184417] win[2]:78(0) - 126(2)
[ 8.184421] win[3]:128(2) - 155(1)
[ 8.184424] win[4]:161(0) - 209(2)
[ 8.184428] win[5]:211(2) - 239(1)
[ 8.184431] win[6]:245(0) - 255(1)
[ 8.184434] ***********************************************
[ 8.184438] **********Tuning values*********
[ 8.184440] **estimated values**
[ 8.184445] T2T_Vmax 58, T2T_Vmin 82, 1'st_hole_Vmax 46, UI_Vmax 86
[ 8.184447] **Calculated values**
[ 8.184451] T2T_Vmax 60, 1'st_hole_Vmax 44, UI_Vmax 83
[ 8.184454] T2T_Vmin 60, 1'st_hole_Vmin 44, UI_Vmin 83
[ 8.184457] ***********************************
[ 8.184463] ***********final tuning windows**********
[ 8.184466] win[0]: 11 - 34
[ 8.184469] win[1]: 55 - 56
[ 8.184472] win[2]: 94 - 112
[ 8.184475] win[3]: 143 - 139
[ 8.184478] win[4]: 177 - 189
[ 8.184481] win[5]: 232 - 223
[ 8.184484] win[6]: 255 - 239
[ 8.184486] ********************************
[ 8.184491] best tap win - (11-34), best tap value 23 prev_best_tap 23
[ 8.184501] sdhci-tegra sdhci-tegra.3: sdhci_tegra_verify_best_tap: tuning freq 200000000hz, best tap 23
[ 8.389387] tegra-snd-rt5639 tegra-snd-rt5639.0: Allocating for stream capture
[ 8.399220] tegra-snd-rt5639 tegra-snd-rt5639.0: snd-soc-dummy-dai <-> tegra-offload-pcm mapping ok
[ 8.411452] mmc0: new HS200 MMC card at address 0001
[ 8.411570] tegra-snd-rt5639 tegra-snd-rt5639.0: rt5639-aif1 <-> tegra30-i2s.1 mapping ok
[ 8.429638] mmcblk mmc0:0001: Card claimed for testing.
[ 8.431512] input: tegra-rt5639 Headphone Jack as /devices/platform/tegra-snd-rt5639.0/sound/card1/input0
[ 8.433216] sysedp_create_consumer: unable to create speaker, no consumer_data for speaker found
[ 8.433217] oprofile: using timer interrupt.
[ 8.467838] GACT probability NOT on
[ 8.468142] mmcblk0: mmc0:0001 SEM32G 29.1 GiB
[ 8.468327] mmcblk0rpmb: mmc0:0001 SEM32G partition 3 4.00 MiB
[ 8.487284] Mirror/redirect action on
[ 8.492911] u32 classifier
[ 8.497592] Actions configured
[ 8.503005] Netfilter messages via NETLINK v0.30.
[ 8.509869] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 8.518564] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 8.518597] Alternate GPT is invalid, using primary GPT.
[ 8.518625] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[ 8.541809] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 8.550053] xt_time: kernel timezone is -0000
[ 8.556709] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.564248] arp_tables: (C) 2002 David S. Miller
[ 8.570903] TCP: cubic registered
[ 8.576362] NET: Registered protocol family 10
[ 8.583712] mip6: Mobile IPv6
[ 8.588529] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 8.595890] sit: IPv6 over IPv4 tunneling driver
[ 8.603206] NET: Registered protocol family 17
[ 8.609529] NET: Registered protocol family 15
[ 8.615754] NET: Registered protocol family 35
[ 8.621920] NET: Registered protocol family 37
[ 8.627931] NET: Registered protocol family 41
[ 8.635351] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 8.670538] Registering SWP/SWPB emulation handler
[ 8.676911] last reset is due to power on reset
[ 8.676911]
[ 8.685967] Disabling clocks left on by bootloader:
[ 8.692381] audio_2x
[ 8.696471] audio
[ 8.700182] audio4
[ 8.703900] audio3
[ 8.707559] audio2
[ 8.711154] audio1
[ 8.714595] audio0
[ 8.718104] hdmi_audio
[ 8.721805] entropy
[ 8.725208] dsi2-fixed
[ 8.728842] dsi1-fixed
[ 8.732470] nor
[ 8.735418] trace
[ 8.738635] sdmmc4_ddr
[ 8.742213] sdmmc3_ddr
[ 8.745735] cclk_lp
[ 8.748947] pll_x_out0
[ 8.752557] pll_m_out1
[ 8.756263] tegra_dvfs: vdd_cpu connected to regulator
[ 8.762500] tegra_dvfs: vdd_core connected to regulator
[ 8.768717] tegra_dvfs: vdd_gpu connected to regulator
[ 8.776172] cpu_cold cooling device is registered
[ 8.781817] cpu_hot cooling device is registered
[ 8.781893] Tegra CPU DFLL is initialized with use_dfll = 1
[ 8.781950] CPU rate: 696 MHz
[ 8.958221] tegra dvfs: tegra sysfs cap interface is initialized
[ 8.965164] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[ 8.973153] tegra_actmon.emc: Completed initialization (0)
[ 8.979810] tegra_actmon.avp: Completed initialization (0)
[ 8.986384] tegra_mon.cpu_emc: Completed initialization (0)
[ 8.995549] reg-aon-1v2: incomplete constraints, leaving on
[ 9.002151] reg-aon-1v8: incomplete constraints, leaving on
[ 9.008740] reg-dcdc-1v2: incomplete constraints, leaving on
[ 9.015454] reg-5v0-supply: incomplete constraints, leaving on
[ 9.022387] avdd-hdmi-pll: incomplete constraints, leaving on
[ 9.029292] usb0-vbus: incomplete constraints, leaving on
[ 9.035890] vpp-fuse: incomplete constraints, leaving on
[ 9.042448] vdd-2v7-cam: incomplete constraints, leaving on
[ 9.049321] avdd-spi: incomplete constraints, leaving on
[ 9.055977] vdd-1v1-cam: incomplete constraints, leaving on
[ 9.062941] vdd-1v2-cam: incomplete constraints, leaving on
[ 9.069896] avdd-cam: incomplete constraints, leaving on
[ 9.076673] vdd-cam: incomplete constraints, leaving on
[ 9.083366] as3722-sd3: incomplete constraints, leaving on
[ 9.090348] vdd-3v3-aon: incomplete constraints, leaving on
[ 9.097440] vdd-ac-bat: incomplete constraints, leaving on
[ 9.104446] regulator-dummy: incomplete constraints, leaving on
[ 9.112630] gpio wake51 for gpio=128
[ 9.117950] input: gpio-keys.3 as /devices/platform/gpio-keys.3/input/input1
[ 9.127329] as3722-rtc as3722-rtc.1: setting system clock to 2017-05-25 18:31:48 UTC (1495737108)
[ 9.140314] ALSA device list:
[ 9.144415] #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 9.150983] #1: tegra-rt5639
[ 9.156098] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 9.167160] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 9.238458] EXT4-fs warning (device mmcblk0p1): ext4_clear_journal_err:4498: Filesystem error recorded from previous mount: IO failure
[ 9.253594] EXT4-fs warning (device mmcblk0p1): ext4_clear_journal_err:4499: Marking fs in need of filesystem check.
[ 9.269827] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended
[ 9.284195] EXT4-fs (mmcblk0p1): recovery complete
[ 9.291689] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.303188] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.311441] devtmpfs: mounted
[ 9.316468] Freeing unused kernel memory: 496K (c0b10000 - c0b8c000)
[ 9.567524] udevd[143]: starting version 3.2
[ 9.596000] udevd[144]: starting eudev-3.2
[ 9.732093] EXT4-fs (mmcblk0p1): re-mounted. Opts: data=ordered
[ 10.111815] EXT4-fs error (device mmcblk0p1): ext4_mb_generate_buddy:755: group 33, 19875 clusters in bitmap, 19891 in gd
[ 10.127182] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p1, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[ 10.445508] udevd[269]: did not find firmware file 'gk20a/gpmu_ucode.bin'
[ 10.459110] udevd[269]: did not find firmware file 'gk20a/NETB_img.bin'
[ 10.470020] udevd[269]: did not find firmware file 'gk20a/fecs.bin'
[ 10.479616] udevd[269]: did not find firmware file 'gk20a/gpccs.bin'
