What is the correct value of pkc_disable for PKC?
There are contradictory descriptions in an app note and in the l4t doc.
So, what is the correct value of pkc_disable for PKC?
NVIDIA Jetson Nano Fuse Specification
L4T Doc
Fuses and Security
And in the README_secureboot.txt located in the bootloader folder the default values are:
PKC - 0x1, NS - 0x1 (T210)
which is not equal with :
L4T Doc
PKC: 0x01 (T194)
NS: 0x00 (T210)
Fuses and Security
We can see the contradiction. Will check and update the correct setting of pck_disable.
We have clarified it and here is the correct value:
    |      1| pkc_disable         | PKC - 0x0, NS - 0x1               |
For enabling secureboot, please burn all fuses with -p in one step. Such as:
$ sudo ./odmfuse.sh -i 0x21 -c PKC -p -k …/emi_pkc.pem -o 0x0000000000000000000000000000000000000000000000000000000100000000
Thanks for the confirmation.
OK, will do.
Hi Dane,
I ran this command, but I did it as such:
sudo ./odmfuse.sh -i 0x21 -c PKC -p -k ~/rsa_priv.pem -o 0x1234567812345678123456781234567812345678123456781234567812345678
Which resulted in my pkc_disable fuse being set to 0x1… Are some of the 256 user-definable fuses shared with pkc_disable? Is that the issue or is something else going on?
hello nathan547,
please apply nvtboot binaries in post #27 of discussion thread Topic 144888, which has correct the fuse burn issues.
thanks
