I refer to the following documents.
http://docs.nvidia.com/drive/nvvib_docs/index.html
( -> NvMedia Sample Applications
-> NvMediaImage from RAW Image Sensor to CUDA Consumer on dGPU (nvmipp_bayerdpu) )
---- Excerpt ----
The image producer reads image data from an input file and posts it to the CUDA consumer through eglStream. In FIFO mode, if the input to the image producer and output of the CUDA consumer bit match, then the test is successful. In Mailbox mode, the number of frames acquired by the consumer depends on the speech at which the producer and consumer are running. You cannot compare input and output files directly in Mailbox mode. The image producer accepts YUV420 or RAW formats as input.
I will ask 4 question.
Question 1. What is the interpolation method specifically described above with demosaic?
Question 2. Is ACPI possible by changing the setting?
(ACPI = Advanced Color Plane Interpolation)
Question 3. Does the sample application do demosaic included in
Fastvideo - GPU Image Processing SDK?
http://www.nvidia.com/content/gpu-applications/PDF/gpu-applications-catalog.pdf
Question 4. If the answer to question 3 is No, which application is included?
Notice
I do not have permission to refer bin files and documents yet in DevZone.
Best regards
