What is the difference between different target hardware for Jetpack
When install Jetpack, need to choose different target hardware. What is the difference between different target hardware for Jetpack?I know p3668-0001 for NX module,p3668-0000 for developer kit,
But I don’t know exactly what the difference is, if you make the wrong choice, what’s the effect?
Hi @baijianping1989 ,
You can find an expression here about the difference between Jetson developer kits and Jetson modules.
Hope it helps.
hello baijianping1989,
please check developer guide, you’ll see the table shown in Devices Supported by This Document.
there’re…
Jetson Xavier NX (P3668-0000) Developer kit (SD-card) version,
Jetson Xavier NX (P3668-0001) Production (eMMC) version.
thanks
