IGX Thor supports DRAM Memory ECC, while Jetson Thor does not. However, the Jetson Thor datasheet specifies support for Alt-link ECC.
What is the difference between DRAM Memory ECC and Alt-link ECC?
Is the lack of DRAM Memory ECC support on Jetson Thor limited by hardware or software?
Thanks for filing the ticket.
I am internally researching about Alt-link ECC and inline ECC.
I will get back to this ticket once I get confirmed.
Inline ECC
- Pro : Works with any standard LPDDR5 part; no dedicated pins
- Con : Costs ~10% extra bandwidth and 6.25% of DRAM capacity
Alt-link Ecc
- Pro : No extra bandwidth, no capacity carve-out — more usable DRAM and throughput
- Cons : Non-standard; requires specific LPDDR5x parts
- Inline ECC : SW
- Alt-link ECC: Memory
Thank you for your reply.
