What is the difference between Jetpack 4.6(rev1) and 4.6(rev3)?
I am using Nvidia Jetson Xavier NX carrier board. Previous time, I installed [Jetpack 4.6(rev1)] 4 months ago and it has been working very well.
This time I tried to install [Jetpack 4.6(rev1)] for another Nvidia Jetson Xavier NX board in order to create the same environment like the previous’ one. However, [Jetpack 4.6(rev1)] is not available when I try to install on SDK Manager. Only [Jetpack 4.6(rev3) is available to install.
How can I find [Jetpack 4.6(rev1) ?Is it possible to install [Jetpack 4.6(rev1)] to my Jetson Xavier NX board?"
Than you very much for your support
Best regards
Kadir
From L4T version point of view, they’re the same R32.6.1.
You could just use current version to reflash your device.
Thank you for kind response.
I understand that I can I use this version for my device. But I would like to learn the difference of both version. If it is all the same why updated to 4.6(rev3)? I need to explain to my Japanese customer about the difference of both version. I regularly buy the same product and install the same version for my customer. Please give me more information about this. Thank you
Best regards
Kadir
The new revision is for Xavier Industrial:
JAXI not boot
For Xavier NX, there is no deviation. FYI.
Hi
You mean, the new version has updated for fixing the flash problem for other product and It doesn’t any affect to system OS, so both revision are the same L4T 32.6.1. right? I got it.
Thank you for your support.
