What is the difference between P3701-0000 and P3701-0004?
I thought the same program could be used for both
7023 for Jetson AGX Orin (P3701-0000 Developer Kit module)
7223 for Jetson AGX Orin (P3701-0004 with 32GB)
Therefore, the program executable using P3701-0000 is executed in P3701-0004 but the results are different.
USE ORIN EVB
0325_EVB_7023.log (105.3 KB)
0325_EVB_7223.log (103.1 KB)
USE Custom Board
0325_CUSTOM_7023.log (91.7 KB)
but 7223 + custom board no any message …
Are there any other special modifications that need to be made?
Are “7023 for Jetson AGX Orin (P3701-0000 Developer Kit module)” and " 7223 for Jetson AGX Orin (P3701-0004 with 32GB) " compatible… Can two CPU modules burn the same version of the program?
Both module could be flashed with NV devkit. If it fails on your carrier board, please review the hardware design.
As I mentioned here,
CUSTOM BOARD + (P3701-0000 Developer Kit module) :
Can display messages and can be burned
Can enter recovery mode
[2006584.820063] usb 1-8: new high-speed USB device number 92 using xhci_hcd
[2006584.970460] usb 1-8: New USB device found, idVendor=0955, idProduct=7023, bcdDevice= 4.01
[2006584.970474] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2006584.970479] usb 1-8: Product: APX
[2006584.970484] usb 1-8: Manufacturer: NVIDIA Corp.
CUSTOM BOARD + (P3701-0004 with 32GB) :
Unable to display message, unable to burn
Can’t enter recovery mode
ORIN EVB BOARD +(P3701-0004 with 32GB) :
[2006699.905355] usb 1-8: new high-speed USB device number 93 using xhci_hcd
[2006700.056382] usb 1-8: New USB device found, idVendor=0955, idProduct=7223, bcdDevice= 4.01
[2006700.056396] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2006700.056402] usb 1-8: Product: APX
[2006700.056407] usb 1-8: Manufacturer: NVIDIA Corp.
進不去recovery mode就是電路設計問題 recovery mode沒有任何software參與
why use (P3701-0000 Developer Kit module) can enter recovery mode
but use (P3701-0004 with 32GB) can’t enter recovery mode ???
