- Xavier module has SYS_VIN_HV and SYS_VIN_MV, max power of xavier module is 30W, then what is the distribution of xavier module 30W power on SYS_VIN_HV and SYS_VIN_MV ?
- TPS53015 is used on the carrier board of xavier module ,it is 9.5A of output.
If total four xavier modules are used on my self-design carrier board, then can TPS53015 power to four xavier modules ?
Hi, the power distribution depends on use case, the total power consumption is also by use case. TPS53015 is for carrier board usage, its power consumption depends on how to use it, you can estimate it based on your own design.
