What is the implementation of NMS of nvinfer
I wanted to know if the DeepStream NMS implementation of the nvinfer plugin is open source. If yes, where can I find it?
Thank you
Hi @mfoglio,
To the best of my knowledge, DeepStream sources are no longer publicly available on the web. However, some of them are distributed within the DeepStream .deb package.
What you are looking for is in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/nvdsinfer_context_impl_output_parsing.cpp. The method is called nonMaximumSuppression and it is defined around line 208 depending on the version you are using.
Thank you, @miguel.taylor .
