What is the limit of concurrent processes on Orin Nano using Python?
• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version 8.6.2
I am using a program similiar to this one deepstream_python_apps/apps/deepstream-rtsp-in-rtsp-out/deepstream_test1_rtsp_in_rtsp_out.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub and I wanted to know how many inputs it can have at the same time on a Orin Nano. When I try to run too many processes at the same time, I get this
I got this when I was running the link-out program with 3 links and another one that also takes these 3 links and writes the inferences info on a sqlite database. With 3 links-out and 2 links into database, it runs.
I plan to otimize the code, maybe merge both programs into one, but I wanted to know if I had a perfect optimized code, what would be the expected amount of inputs I could read at the same time.
For more info:
Here is the main function of link out program
def main(args):
    # Initialize GStreamer and RTSP server
    Gst.init(None)
    server = GstRtspServer.RTSPServer.new()
    server.props.service = "8554"
    server.attach(None)
    pipelines = []
    osdsinkpads = []  # Store osdsinkpads for each pipeline
    starting_udp_port = 5400
    for i, input_file in enumerate(args.input):
        udp_port = starting_udp_port + i
        rtsp_mount_point = f"/ds-test-{i}"
        pipeline, codec, nvosd = create_pipeline(
            input_file,
            udp_port,
            args.codec,
            args.bitrate,
            args.enc_type
        if pipeline:
            pipelines.append(pipeline)
            # Store the osdsinkpad for this nvosd
            osdsinkpad = nvosd.get_static_pad("sink")
            if not osdsinkpad:
                sys.stderr.write(f" Unable to get sink pad of nvosd for input {i} \n")
                continue
            osdsinkpads.append(osdsinkpad)
            # Add probe to the sink pad of nvosd for this pipeline
            osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
            factory = GstRtspServer.RTSPMediaFactory.new()
            factory.set_launch(
                f"( udpsrc name=pay0 port={udp_port} buffer-size=524288 "
                f"caps=\"application/x-rtp, media=video, clock-rate=90000, "
                f"encoding-name=(string){codec}, payload=96 \" )"
            factory.set_shared(True)
            server.get_mount_points().add_factory(rtsp_mount_point, factory)
            print(f"\n*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554{rtsp_mount_point} ***\n")
    # Main loop
    loop = GLib.MainLoop()
    for pipeline in pipelines:
        bus = pipeline.get_bus()
        bus.add_signal_watch()
        bus.connect("message", bus_call, loop)
        ret = pipeline.set_state(Gst.State.PLAYING)
        if ret == Gst.StateChangeReturn.FAILURE:
            print("Failed to set pipeline to PLAYING")
            return 1
    try:
        loop.run()
    except Exception as e:
        print(f"Main loop terminated: {e}")
    # Cleanup
        pipeline.set_state(Gst.State.NULL)
Here is the main function of the database one
def main(input_files, db_file, labels_file, ignore_background, location):
    labels = load_labels(labels_file)
    background_class = labels[0] if labels else "background"
    lock = threading.Lock()
    frame_queue = Queue()
    def write_worker():
        aggregated_data = {}
        while True:
            frame_data = frame_queue.get()
            if frame_data is None:
                break
            for key, value in frame_data.items():
                if key not in aggregated_data:
                    aggregated_data[key] = value
                else:
                    for label, count in value.items():
                        aggregated_data[key][label] = aggregated_data[key].get(label, 0) + count
            if frame_queue.qsize() == 0:
                write_to_sqlite(aggregated_data, db_file, labels, background_class, ignore_background, location, lock)
                aggregated_data.clear()
    with ThreadPoolExecutor(max_workers=len(input_files) + 1) as executor:
        executor.submit(write_worker)
        futures = [
            executor.submit(process_stream, input_file, stream_id, db_file, labels, background_class, ignore_background, location, lock, frame_queue)
            for stream_id, input_file in enumerate(input_files, start=1)
        for future in futures:
            future.result()
        frame_queue.put(None)
I will probably replace ThreadPoolExecution with ProcessPoolExecutor. Not sure if it will increase amount of possible inputs though, worth a try at least.
It depends on the CPU/GPU usage of your program.
However, I noticed that you are using orin nano, which does not support hardware encoding.
In order to support more inputs, here are some tips:
  1. Set the CPU frequency to the highest
    VPI - Vision Programming Interface: Performance Benchmark
  2. Adjust the encoding parameters of x264/x265 to reduce CPU consumption.
thanks!
