What is the load address of U-Boot in Jetson TK1?
When Jetson TK1 board is booted up, the u-boot loader must be loaded in some specific address in memory where the processor control is transferred to. I need to know he address the boot-loader is loaded at.
From u-boot sources, how can I verify the load address assuming that the load address is present somewhere in the configuration/header file?
Hi Holmes
You can boot to the u-boot and use printenv to show the information like below.
Tegra210 (P2371-2180) # printenv
arch=arm
baudrate=115200
board=p2371-2180
board_name=p2371-2180
boot_a_script=load ${devtype} ${devnum}:${bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}:${bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc1 mmc0 usb0 pxe dhcp
bootcmd=run distro_bootcmd
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=2
cpu=armv8
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
fdt_addr_r=0x82000000
fdt_copy_node_names=/memory-controller@7001b000
fdt_copy_src_addr=0x83080000
fdt_high=ffffffffffffffff
fdt_remove_property_names=/pinmux@700008d4/pinctrl-names
initrd_high=ffffffffffffffff
kernel_addr_r=0x80080000
loadaddr=0x80080000
lp0_vec=0x1000@0xff2bf000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
nvdumper_reserved=0xff23f000
pxefile_addr_r=0x90100000
ramdisk_addr_r=0x83100000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${bootpart}...; for prefix in ${boot_prefixes}; do run scan_de
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1e
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${bootpart} ${prefix}extlinux/extlinux.conf; then echo Foundi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${bootpart} ${prefix}${scrie
scriptaddr=0x90000000
soc=tegra210
stderr=serial
stdin=serial
stdout=serial
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=nvidia
Environment size: 2436/8188 bytes
