What is the maximum audio duration?
I tried to add a 6 minute clip, and got a message ‘Audio is too long to resample’
We recommend not go over a minute. But in some cases, it can go up to 1.5 minutes.
OK, I will keep that in mind.
I created a 4 minute and 36 seconds script, and it worked.
@Ehsan.HM what are some of the potential drawbacks from using longer audio clips?
44100hz audio usually problematic as it is not multiple of 16000hz (target sample rate). If the input audio is 16000hz or 48000hz, long audio is okay. we cannot use a long 44100hz audio.
got it. thanks for the explanation 👍
