Hello folks!
Is there any limit to the SATA HDD capacity that can be connected to Jetson TK1?
I know there is a 2TB partition limit in MBR filesystems.
But I would like to know is there anything which would prevent me from using a 4TB GPT partition with my Jetson TK1.
Thank you.
-Davy
SATA controller on TK1 is standard (Rev 3.1), would have no limit to HDD capacity as others.
Thank you for the information!
Do beware that the TK1 is a 32-bit system. The drive controller itself won’t have special limitations, nor will the TK1 compared to other 32-bit systems…but 32-bit systems in general are limited in comparison to 64-bit systems. U-Boot understands GPT so booting from many/large GPT partitions won’t be an issue (Jetsons don’t have a BIOS), plus the kernel understands GPT. 32-bit addressing is still a limitation if you compare to 64-bit.
