jvg
January 18, 2022, 5:07pm
#1
Good afternoon!
I have trained a cnn model in Matlab. Then, I exported it to a Jetson Nano
as an ONNX model. Finally, I converted it into a TensorRT engine, which I named ecg_net.trt.
With ecg_net.trt, I have tried to make an inference with a “dummy batch” as an input.
The thing is: the code does not throw any error but I am not sure that the output of the model has any sense. Maybe I am skipping some step or misunderstanding the output.
Here is the image of the output:
I will put here the files to reproduce the error/issue:
ecg_net.onnx (946.0 KB)
main.py (4.9 KB)
Any help would be much appreciated.
P.D. It´s my first time opening a topic here so feel free to correct any mistake I may be making. And again, thanks.
We run your ONNX model with trtexec tool and the output looks good for us.
$ /usr/src/tensorrt/bin/trtexec --onnx=ecg_net.onnx --dumpOutput
&&&& RUNNING TensorRT.trtexec [TensorRT v8001] # /usr/src/tensorrt/bin/trtexec --onnx=ecg_net.onnx --dumpOutput
[01/18/2022-22:02:03] [I] Explanations of the performance metrics are printed in the verbose logs.
[01/18/2022-22:02:03] [I] Output Tensors:
[01/18/2022-22:02:03] [I] softmax: (1x2)
[01/18/2022-22:02:03] [I] 0.880822 0.119178
&&&& PASSED TensorRT.trtexec [TensorRT v8001] # /usr/src/tensorrt/bin/trtexec --onnx=ecg_net.onnx --dumpOutput
[01/18/2022-22:02:03] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1353, GPU 13366 (MiB)
Guess that there is some issue in the main.py .
You can find an example for running TensorRT with the ONNX model below.
Would you mind giving a check to see if anything is missing in your code first?
https://elinux.org/Jetson/L4T/TRT_Customized_Example#OpenCV_with_ONNX_model
system
closed
February 9, 2022, 5:43am
#5
