What is the minimum image size without argus supported by Jetson AGX Orin?
Get RAW images without using argus with MIPI D-PHY.
Use with very small image sizes and high frame rates.
What is the minimum image size without arguments supported by Jetson AGX Orin?
Also, is there an upper limit to the frame rate?
hello K.M,
may I know what’s the real use-case?
actually, we recommend using a camera with a frame rate of less than or equal to 60 FPS.
