What is the minimum size of NVME tha can be used for Orin Nx
Our application is real time target tracking and run some AI algorithms on Jetson Orin Nx, size of our applications and libraries are not much and will be less than10GB.
We are making a custom carrier board, what is the minimum size of NVME SSD that can be used?
As noted in the Developer Guide describes, external storage of 64GB or larger is supported by default. For smaller storage devices, please adjust ROOTFSIZE and num_sectors in the board configuration and partition layout according to your use case.
Thank you,
