we are designing a custom board, which includes sending video data via MIPI from FPGA(D-PHY) to Nvidia SOM, the voltage level supported by the FPGA is 1.2V and 1.8V.
Does the SOM also supports 1.2V voltage level?
If not, then what voltages are supported by SOM?
Is there any document that I can follow which details these parameters?
Can we connect these signals on FPGAs 1.8V banks?
Hello @Trumany ,
I wanted to know what is the voltage standard that has been adopted by nvidia for jetson orin 64 agx som?
Or does this som supports all the voltage standards mentioned in mipi sheet?
In the datasheet it is mentioned that it can run at LVDS, 1.2 volts and 1.8 volts.
I hope i am not causing any confusion.
Hi, if you looked into the MIPI Alliance Specification for D-PHY, version 1.2 which is supported by Xavier, you will get below info that indicates 1.2V for LP. If you mean the SLVS camera, you can find the related chapter in Design Guide.
