I have a Jetson Orin AGX and a 2x 10Gb Network PCIE card.
I was pleasently surprised the card just worked plug’n’play with no additional driver setup required!
As an initial test I can use it as is, however on the long run this feels insecure and I risk damaging both the card and Jetson.
What is the recommended method of mounting and securing a PCIE card on Jetson Orin AGX ?
(Are there any existing brackets / enclosures ? Would one need to design and manufacture it ?)
I’ve started testing using this card: Intel Dual Port PCIe 10GbE Server/Workstation Ethernet Network Adapter X540T2BLK OEM.
My question is regarding how to physically secure the board so it can’t accidentally move around.
(e.g. on a typical motherboard there’s a notch that locks the board in place so it can’t accidentically be taken out while the computer is powered on).
Would you happen to have any suggestions on how to lock the board so it’s stable ?
Just for personal use you may 3d-print something. There is nothing you can buy - the devkit is only meant for laboratory use.
For a product to sell your should have a look at this carrier board:
This already has got two 10G Ethernet ports onboard (plus two 1G), and while the Intel X540 only supports 1G and 10G this board also supports 2.5G and 5G Ethernet speeds on both of the 10G ports.
