What is the torchvision version compatible with torch 1.11.0a0+17540c5
the below message was appeared when executing the program on jetson tx2 with jetpack version 4.6.5:
"Couldn’t load custom C++ ops. This can happen if your PyTorch and "
RuntimeError: Couldn’t load custom C++ ops. This can happen if your PyTorch and torchvision versions are incompatible, or if you had errors while compiling torchvision from source. For further information on the compatible versions, check GitHub - pytorch/vision: Datasets, Transforms and Models specific to Computer Vision for the compatibility matrix. Please check your PyTorch version with torch.version and your torchvision version with torchvision.version and verify if they are compatible, and if not please reinstall torchvision so that it matches your PyTorch install
Based on the list shared in the below topic:
Please install TorchVision 0.3.0.
Instructions
Installation
PyTorch v1.1 - torchvision v0.3.0
