We are currently designing a custom carrier board based on the Seeed Studio reComputer J401 reference design.
Our requirement is to support both Jetson Orin Nano and Jetson Orin NX, including SUPER MAXN_SUPER mode on Orin Nano and NX.
According to the latest Jetson Orin NX/Nano Product Design Guide v1.5, VDD_IN supports a 5–20 V range, and the MODULE_ID is used to determine the appropriate VDD_IN voltage.
We would like to confirm the following before finalizing our carrier-board design:
Do current Jetson Orin Nano modules support the 5–20 V VDD_IN range, or are they still limited to 5 V (maxn super mode)?
Can we use a 12 V VDD_IN supply for both Orin Nano and Orin NX (maxn super mode)?
For a carrier board supporting both modules, should we implement a MODULE_ID-controlled VDD_IN voltage-selection circuit?
We would appreciate your confirmation of the recommended VDD_IN architecture for a new carrier board.
Jetson Orin Nano supports a nominal 5V VDD_IN only, including when operating in MAXN_SUPER mode. Do not apply 12V directly to the VDD_IN pins of an Orin Nano module.
If you intend to support both Jetson Orin NX and Orin Nano on the same carrier board, you need to implement a MODULE_ID controlled circuit that select the appropriate VDD_IN voltage, as shown in the NVIDIA reference carrier baord design.
Additionally, could we consider whether supplying a higher voltage with lower current to the Super Orin NX—for example, 19V with a lower current, similar to MAXN Super mode—has any advantages?
Would this approach reduce power dissipation or improve efficiency in any way?
Yes. For the same power, using 19 V reduces the input current, which can reduce I²R losses, voltage drop, and heating in the cables, connectors, and carrier-board power path. This is beneficial for stable power delivery in MAXN SUPER mode.
However, it does not necessarily improve the overall system efficiency or significantly reduce the SoC temperature, since the result also depends on the efficiency of the onboard DC-DC converters. Therefore, the main advantage of 19 V is lower power-distribution loss and better power-delivery margin.
Please implement a circuit that select the appropriate voltage supplied to VDD_IN according to the MODULE_ID signal. For implementation details, please refer to the section of the reference schematic where the VDD_CVM voltage source is selected according to MODULE_ID.
Actually we have designed our schematics. but once we flashed the mcu firmware by the nvidia provided firmware. how it will work like we dont want to change the signals (automatically the firmware recognizes the som pin state) or we should change the pin state!?
Please note that the VDD_IN voltage selection is implemented by the hardware logic on the reference carrier board. MODULE_ID is floating on the Jetson Orin NX module which supporting wide VDD_IN range (5V-20V) and pulled low on the Jetson Orin Nano module.
The carrier board circuity directly uses this state to select the appropriate voltage source for VDD_IN. Therefore, the MCU firmware does not need to detect or change the MODULE_ID signal for voltage selection.
