JetPack Version Used: 4.4
Kernel Version Used: 4.4
Hello. I’m bhyim
I received the source_release.tbz2 file through the Jetson/TX2 SPI - eLinux.org site.
Uncompressed and moved to /sources/kernel/kernel-4.4 to:
Note: The following sites have been referenced in the course of performing:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/kernel_custom.html#wwpID0E0LD0HA
$ TEGRA_KERNEL_OUT= ----- > output directory path settings
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
→ Here’s the error, and here’s the following:
make[1]: Entering directory ‘/home/nvidia/sources/kernel/build’
** GEN ./Makefile**
** HOSTCC scripts/kconfig/zconf.tab.o**
scripts/kconfig/zconf.tab.c:211:10: fatal error: zconf.hash.c: No such file or directory
** #include “zconf.hash.c”**
compilation terminated.
scripts/Makefile.host:108: recipe for target ‘scripts/kconfig/zconf.tab.o’ fai led
make[2]: *** [scripts/kconfig/zconf.tab.o] Error 1
/home/nvidia/sources/kernel/kernel-4.4/Makefile:542: recipe for target ‘tegra1 8_defconfig’ failed
make[1]: *** [tegra18_defconfig] Error 2
make[1]: Leaving directory ‘/home/nvidia/sources/kernel/build’
Makefile:150: recipe for target ‘sub-make’ failed
make: *** [sub-make] Error 2
the action I took
- modify tegra_decinfig to tegra18_deconfig >> fail
- delete ARCH=arm64 O=$TEGRA_KERNEL_OUT >> fail
- Run maketegra18_deconfig >> Successful
Successfully obtained .config file.
After successful, perform the following command:
$ make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4 → fail
Error is…
arch/arm64/kernel/topology.c: In function ‘parse_cluster’:
arch/arm64/kernel/topology.c:114:40: error: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 3 [-Werror=format-truncation=]
snprintf(name, sizeof(name), “cluster%d”, i);
arch/arm64/kernel/topology.c:114:32: note: directive argument in the range [0, 2147483647]
arch/arm64/kernel/topology.c:114:3: note: ‘snprintf’ output between 9 and 18 bytes into a destination of size 10
skip…
arch/arm64/kernel/topology.c:59:3: note: ‘snprintf’ output between 8 and 17 bytes into a destination of size 10
snprintf(name, sizeof(name), “thread%d”, i);
cc1: all warnings being treated as errors
scripts/Makefile.build:261: recipe for target ‘arch/arm64/kernel/topology.o’ failed
make[1]: *** [arch/arm64/kernel/topology.o] Error 1
Makefile:973: recipe for target ‘arch/arm64/kernel’ failed
make: *** [arch/arm64/kernel] Error 2
I couldn’t start from here.
I have a question about this.
I would like to know the exact reason and solution for the “-Werror=format-truncation” error.
JetPack 4.3 is a convenient kernel compilation using scripts from buildJetsonKernel.
Is there no script available in JetPack 4.4 like this?
Thank you to those who help me.
