From jetpack 4.4 to jetpack 4.6, for example, there is a problem that binaries built in version 4.4 do not work with versions 4.5 and 4.6.
When going from 4.4 to 4.6, there were cases where the build failed due to a fix in the TensorRT library.
What level of backwards compatibility can be considered in jetson?
Thank you.
We don’t know what it is, please be more specific.
Could you fix your application?
Usually the backward compatible is not the consideration for development. When new feature required at new release, then should consideration to do the upgrade.
