What means this "libargus offers a low-level frame-synchronous API for camera applications, with per frame camera parameter control, multiple (including synchronized) camera support, " at L4T R32.2.1?
Is that means I can use MIPI CSI input 8 or 12 ways videos to TX2 at L4T R32.2.1?
How can I do this?
Yes, that’s correct. But now current argus have issue to support above 6 cameras. We are still working to fix it to support to 12 sensors with virtual channel.
Hi Sensor Test,
From your question: Is that means I can use MIPI CSI input 8 or 12 ways videos to TX2 at L4T R32.2.1?
If you want to get 8 or 12 outputs from a single input source, this could be possible by creating N number of OutputStreams for single input CaptureSession based on your requirement.
You can refer the documentation present in
[url]https://docs.nvidia.com/jetson/l4t-multimedia/index.html[/url]
For reference you can check multiStream sample provided in tegra_multimedia_api/argus/samples in which the single camera input source is used for concurrently capturing jpeg images as well as streaming using OpenGL renderer.
