What plugin do you recommend your customers implement?
Continuing the discussion from Camera + LiDAR Solution in Deepstream:
• Hardware Platform (Jetson / GPU) : Jetson AGX Orin or 3080
• DeepStream Version :
• JetPack Version (valid for Jetson only) : 5.0.2
• TensorRT Version :
• NVIDIA GPU Driver Version (valid for GPU only) :
• Issue Type( questions, new requirements, bugs) :
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) :
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) :
We use Jetson Orin and 3080 on Noubeau IPC.
From the previous talk, mchi, NVIDIA moderator, said that Lidar plugin have to be written by nivida users. So I wonder which plugin is that.
  1. Do we need to write/implement plugin for Deepstream?
  2. And still DS doesn’t provide plugin for lidar yet?
Hi @jhjo
We will provide the Lidar plugin and pipeline in DeepStream 6.2 release which is coming very soon.
I’d like to know when it would happen!
Thank you very much!
DeepStream 6.2 GA is available now.
