What 's the minimum time to reset the pin"PERIPHERAL_RESET_N"
hello Username1,
may I know what’s your actual use-case?
you may refer to Jetson AGX Xavier Series Module Data Sheet for the reset behavior.
thanks
Hi,jerry
Xavier working as a devie,when the devie can’t respond to the host,host need to reset the soc by “PERIPHERAL_RESET_N”.
So we need to know the minimun reset time,we can’t find any revelant information in datasheet.
Could you tell us directly?
There is no critical timing on this, you can set a couple of ms for it as general.
