Hello!!
When the request was sent to L2 cache to get the data which miss in L1 cache, the address bus and the commend bus will deliver the request to L2 (or DRAM). However i want to know the size of the address bus and the commend bus and the data bus .Is the size of data bus equal to the width of memory(256 bits).I use the GTX 1070 Ti for my experiment.
Not sure exactly what you’re asking but check out https://docs.nvidia.com/cuda/pascal-tuning-guide/index.html
1.4.3.2. Unified L1/Texture Cache
Like Maxwell, Pascal combines the functionality of the L1 and texture caches into a unified L1/Texture cache which acts as a coalescing buffer for memory accesses, gathering up the data requested by the threads of a warp prior to delivery of that data to the warp. This function previously was served by the separate L1 cache in Fermi and Kepler.
By default, GP100 caches global loads in the L1/Texture cache. In contrast, GP104 follows Kepler and Maxwell in caching global loads in L2 only, unless using the LDG read-only data cache mechanism introduced in Kepler. As with previous architectures, GP104 allows the developer to opt-in to caching all global loads in the unified L1/Texture cache by passing the -Xptxas -dlcm=ca flag to nvcc at compile time.
Kepler serviced loads at a granularity of 128B when L1 caching of global loads was enabled and 32B otherwise. On Pascal the data access unit is 32B regardless of whether global loads are cached in L1. So it is no longer necessary to turn off L1 caching in order to reduce wasted global memory transactions associated with uncoalesced accesses.
Unlike Maxwell but similar to Kepler, Pascal caches thread-local memory in the L1 cache. This can mitigate the cost of register spills compared to Maxwell. The balance of occupancy versus spilling should therefore be re-evaluated to ensure best performance.
Two new device attributes were added in CUDA Toolkit 6.0: globalL1CacheSupported and localL1CacheSupported. Developers who wish to have separately-tuned paths for various architecture generations can use these fields to simplify the path selection process.
Note: Enabling caching of globals in GP104 can affect occupancy. If per-thread-block SM resource usage would result in zero occupancy with caching enabled, the CUDA driver will override the caching selection to allow the kernel launch to succeed. This situation is reported by the profiler.
