What to use instead of `nvonnxparser::IParser::destroy()`?
I have some code that calls the deprecated function nvonnxparser::IParser::destroy() - the API notes that this is deprecated but doesn’t suggest an alternative, how should I modify my code to not use this deprecated lib function?
The warning:
warning: 'virtual void nvonnxparser::IParser::destroy()' is deprecated [-Wdeprecated-declarations] parser->destroy();
the code in context:
    nvinfer1::IBuilder *builder =
        nvinfer1::createInferBuilder(gLogger.getTRTLogger());
    assert(builder != nullptr);
    const auto explicitBatch =
        1U << static_cast<uint32_t>(
            nvinfer1::NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
    auto network = builder->createNetworkV2(explicitBatch);
    auto config = builder->createBuilderConfig();
    auto parser = nvonnxparser::createParser(*network, gLogger.getTRTLogger());
    if (!parser->parseFromFile(
            modelFile.c_str(),
            static_cast<int>(gLogger.getReportableSeverity()))) {
      gLogError << "Failure while parsing ONNX file" << std::endl;
    // Build the engine
    builder->setMaxBatchSize(BATCH_SIZE);
    config->setMaxWorkspaceSize(2300_MiB);
    config->setFlag(nvinfer1::BuilderFlag::kFP16);
    std::cout << "start building engine" << std::endl;
    nvinfer1::IHostMemory*  serializedModel = builder->buildSerializedNetwork(*network, *config);
    std::cout << "build engine done" << std::endl;
    assert(engine);
    // we can destroy the parser
    parser->destroy();
Please refer to the following API doc, as mentioned destroy() will be removed from the TensorRT 10.0 onwards.
https://docs.nvidia.com/deeplearning/tensorrt/api/c_api/classnvonnxparser_1_1_i_parser.html#a6eb44b7dcbc7880c9bb11663424a3e14
We can just use the destructor. or delete/free if it’s a pointer.
