• Hardware Platform (Jetson / GPU) :Jetson
• DeepStream Version:5.1
**• JetPack Version (valid for Jetson only)**4.5
• TensorRT Version:7.1.3
Hi guys,
Suppose I create a simple pipeline for musti-stream rtsp source like this:
Solution 1: >> one branch
Sources | streammux | nvinfer | custom_plugin | nvosd | fakesink
Solution 2: >> two branch
Sources | streammux | nvinfer | streamdemuxer | tee name=t | t. custum_plugin -name=b1| nvosd | fakesink | t. custom_plugin -name=b2 | nvosd | fakesink
The aim of custom plugin is that for capture metadata of buffer like this:
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
try:
l_obj = l_obj.next
break
l_frame = l_frame.next
break
So in the solution 1 we have loop as many streams and only once do:
but in the solution 2 we had multi branches as many streams and also we get multiple batch_meta as many streams.
I want to know which of solutions can be efficient in terms of speed and resources used?
I want to know the below lines have overhead if we call multiple times in each of branches or it’s best to have one branch and only call once of them?
