Hello
We want to calibrate the camera using nvmedia.
we found next sample.
home/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/samples/nvmedia/img_cc/drive-px2-a/dvp_o_ar0231_raw12_hdr_1920x1236_ab_ta_rccb_v7
What do the following parameters mean in the file?
How do I modify parameters to proceed with camera calibration?
EX) in the file
#line 68
Exposure control
20 3362 00 00 # C_GAIN 1.0 → How to modify parameters to GAIN 1.2??
hello jinsankim12,
please refer to below,
Exposure control
3362 <== this is the register address for DC_GAIN,
00 00 <== the input values settings
you should also contact the sensor vendor, and please check AR0231 register map for details,
you may also found the documentation under …/nvmedia/docs/nvmimg_cc_user_guide.md, please also refer to the notes and requirement for ar0231 calibration.
thanks
JerryChang:
hello jinsankim12,
Exposure control
thanks
We have analyzed the example and this is an example for initial setting of camera parameters.
I want to change the camera parameter values in real time.
The features I want are in the following document links.
https://docs.nvidia.com/drive/nvvib_docs/index.html#page/NVIDIA%2520DRIVE%2520Linux%2520SDK%2520Development%2520Guide%2Fipp_framework.html%23
Where can I find the NvMedia IPP framework sample code?
thanks
