What's the difference between camera_add and camera_streaming
GPU
• DeepStream Version
7.1
• TensorRT Version
Question
What’s the difference between camera_add and camera_streaming when adding a sensor?
1.curl -XPOST 'http://localhost:9000/api/v1/stream/add' -d '{
  "key": "sensor",
  "value": {
     "camera_id": "uniqueSensorID1",
     "camera_name": "front_door",
     "camera_url": "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4",
     "change": "camera_add",
     "metadata": {
         "resolution": "1920 x1080",
         "codec": "h264",
         "framerate": 30
 "headers": {
     "source": "vst",
     "created_at": "2021-06-01T14:34:13.417Z"
2.curl -XPOST 'http://localhost:9000/api/v1/stream/add' -d '{
 "key": "sensor",
 "event": {
     "camera_url": "rtsp://xyz.mp4",
     "change": "camera_streaming",
     "metadata": {
         "codec": "h264",
         "framerate": 30
 "headers": {
     "source": "vst",
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvmultiurisrcbin.html#add-a-new-stream-to-a-deepstream-pipeline
No difference. Please refer to s_stream_api_impl() function in /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvmultiurisrcbin/gstdsnvmultiurisrcbin.cpp
Thank you.
I asked about this because there are two different sets of documentation on this topic.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_RestServer.html#stream-add-remove
The curl command mentioned above at (2), is only supported when the sample application uses nvmultiurisrcbin.
They are the same.
