We want to evaluate TX2’s video encode&decode efficiency and performance, as i know, gstreamer and multimeida api can both run video encode&decode test case, but what’s the difference between gstreamer and multimedia api?
Which one should I choose for video encode&decode, so that we can get a fairly test result.
Thanks for your reply. From the documentation, I find no much information about their difference, but there is introduction for GStreamer:
GStreamer Framework:
Provides a higher-level Multimedia API. This framework provides a parallel capability to the collection of APIs in the Low-Level Multimedia API.
The GStreamer framework is installed with the download for the Jetson Driver. It is also installed by NVIDIA JetPack.
How to understand the “higher-level”, does it means GStreamer can performance better than Multimedia API?
I get it, did you do some tests to compare their video codec performance? for example, for the same YUV input source, if I set fixQP QP=20 for H.265 encoder, is there any difference for their output stream?
By the way, where can I find GStreamer source code? I know Multimedia API source code is in Tegra_Multimedia_API_R27.1.0_aarch64.tbz2.
gstreamer1.0-plugins-base-apps/xenial-updates,xenial-security,now 1.8.3-1ubuntu0.2 arm64 [installed,automatic]
GStreamer helper programs from the "base" set
gstreamer1.0-plugins-base-dbg/xenial-updates,xenial-security 1.8.3-1ubuntu0.2 arm64
GStreamer plugins from the "base" set
gstreamer1.0-plugins-base-doc/xenial-updates,xenial-security 1.8.3-1ubuntu0.2 all
GStreamer documentation for plugins from the "base" set
gstreamer1.0-plugins-good/xenial-updates,xenial-security,now 1.8.3-1ubuntu0.4 arm64 [installed,automatic]
GStreamer plugins from the "good" set
gstreamer1.0-plugins-good-dbg/xeni
