@gstate @kellyg
I want to create RL environments with multiple rigid bodies and add domain randomization to every rigid body and the agent (robot) in each environment in Isaac Sim.
Because dr in Isaac Sim has to be applied to Views
with the same number of prims (usually num_envs
), in order to add dr to the robot, I have to create one RigidPrimView
for every rigid body in one env to make sure that every RigidPrimView
(for rigid bodies) and ArticulationView
(for the robot) all have num_envs
prims. I suppose this is somehow inefficient when I need to obtain rigid body states (like pose or velocity), as I need to run some for
loop to iterate through every RigidPrimView
and call functions like get_world_poses
for num_rigid_bodies_per_env
times, which is not parallelly optimized in GPU.
However, if I do not add domain randomization or only add dr to rigid bodies, there is a more efficient way to manage multiple rigid bodies, which is creating a single ‘‘large’’ RigidPrimView
containing all rigid body prims. In this way, I only need to call functions like get_world_poses
once and can avoid the for
loop. But the disadvantage is that to apply dr to this “large” View
, we must set num_envs
parameter of dr to be num_envs*num_rigid_bodies_per_env
. If we do so, we cannot add dr to other prims like robots which have only one prim in every environment (which is different from num_rigid_bodies_per_env
Can I still do something similar to create a “large” View
when domain randomization is applied to Views
of different numbers of prims? Or do you have any suggestions for efficiently managing multiple rigid body states and applying dr simultaneously?
