We need to build c++ application based on middle-ware platform similar to ROS provided by third-party company on Jetson Orin. This application is provided as a shared library and loaded with dlopen() by this platform.
Now we got a weird problem: when calling deserializeCudaEngine() to load a tensorrt enginge with QAT, core dump happened, and we got the stack trace as follow:
`Thread 1 “mfrlaunch” received signal SIGSEGV, Segmentation fault.
__strlen_generic () at …/sysdeps/aarch64/multiarch/…/strlen.S:98
98 …/sysdeps/aarch64/multiarch/…/strlen.S: No such file or directory.
(gdb) bt
#0 __strlen_generic () at …/sysdeps/aarch64/multiarch/…/strlen.S:98
#1 0x0000fffff721c958 in __GI__IO_puts (str=0x0) at ioputs.c:35
#2 0x0000ffffdfb337ec in ?? () from /usr/lib/aarch64-linux-gnu/libnvinfer.so.8
#3 0x0000ffffdf857638 in ?? () from /usr/lib/aarch64-linux-gnu/libnvinfer.so.8
#4 0x0000ffffdfaf5ac0 in ?? () from /usr/lib/aarch64-linux-gnu/libnvinfer.so.8
#5 0x0000ffffdcc571a0 in ?? () from /usr/lib/aarch64-linux-gnu/libnvinfer.so.8
#6 0x0000ffffdcc3ea50 in ?? () from /usr/lib/aarch64-linux-gnu/libnvinfer.so.8
#7 0x0000ffffdcc32548 in ?? () from /usr/lib/aarch64-linux-gnu/libnvinfer.so.8
#8 0x0000fffff68d2428 in nvinfer1::IRuntime::deserializeCudaEngine (this=, pluginFactory=0x0, size=, blob=0xfffeac2d4010)
However, if we load an engine without QAT, everything is fine.
Besides, if we build an independent application without that middle-ware platform, the problem engine can be loaded.
