Hello guys, I am struggling to sort out a bizarre issue I have with CUDAFE. Basically I have installed the CUDA SDK Toolkit 3.0 and I recompiled with VS2008 my solution some days ago. All went smoothly. But yesterday (when I installed the Intel C++ compiler 11.x in evaluation period - could the thing be associated with the problem that suddenly appeared??) the solution re-build did not succeed, when I got the following message error:
‘cudafe’ is not recognized as an internal or external command,
1>operable program or batch file.
1>Project : error PRJ0019: A tool returned an error code from “Compiling with CUDA Build Rule…”
1>Build log was saved at “file://c:\Users\marcob\AppData\Local\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src\MAST\x64\Release\BuildLog.htm”
What’s going on?Any ideas?
Many thanks
Best regards
