what's wrong with this simple code
//solved, thanks to Ailleur, and i was muddleheaded then…
“launch time out failure” for below kernel. If i comment the 3 lines with “//CMT”, then it runs ok. Why? Thanks!
 dim3 Dg(1, 1, 1);
 Â dim3 Db(64, 1, 1);
//kernel
	__shared__ int s_top;
	__shared__ int s_offsetQ;
	__shared__ int s_cnt; //throughput of result of this block
	const int tx = threadIdx.x;
	if(tx == 0) //CMT
	{ Â //CMT
 Â s_cnt = 0;
 Â s_offsetQ = blockIdx.x;	//bx
	} //CMT
	while(s_offsetQ < nQ)
 Â if(tx == 0)
 �  �  s_offsetQ += gridDim.x; //block number
 �  __syncthreads();
I would guess that its because s_offsetQ doesnt have a value for every other thread and you still ask that it loops over it.
I would encapsulate the whole thing in if(tx==0).
At this point, only one thread per block will be active though.
thanks! i newly edited my orignial post by adding “…”. I have other lines there, but the problem emerges even those lines are commented.
you said " s_offsetQ doesnt have a value for every other thread ", since it’s shared , i can’t agree. Thanks!
Right you are, i missed the fact that it is shared. There should be a syncthread after the (first) assignment then.
