Wheel´s rotation is not effective
This is a follow up for already solved issue here:
Now I have animated the rotation of the skeleton. The wheel is rotating when I adjust the rotation value, but the saved keyframe is not effective for wheel at scene playback.
What might be the problem?
Hi Pekka, I suggested you please ask about the issue at Create or Machinima channel, since it’s no more an Unreal connect problem. You’ll get the answer more quickly.
Okay, moved it to here, Machinima.
Howdy @pekka.varis ,
From what it appears in your video, that definitely set two keys which should generate a result. Maybe not the one you eventually wanted, but certainly SOMETHING. I will create a bug for this and talk to the animation guys about it.
Thanks for your continued example of teamwork between development and power users!
Ryan
Hey @pekka.varis The current release does not support keyframes on Skel Joints. USD skel joints are not prims. A solution is currently in development and we are adding this feature soon.
