When a new UsdPreviewSurface Texture is created, the Shader connection is not in accordance with the specification
I am checking to see if the USD material UsdPreviewSurface specification is reflected.
Creating-Materials-UsdPreviewSurface Texture in OmniverseCreate will create a Material for the UsdPreviewSurface.
The usda file for the material at this time is as follows.
Some parts have been omitted.
def Material "PreviewSurfaceTexture"
    token outputs:surface.connect = </World/Looks/PreviewSurfaceTexture/PreviewSurfaceTexture.outputs:surface>
    def Shader "PreviewSurfaceTexture"
        uniform token info:id = "UsdPreviewSurface"
        float inputs:clearcoat = 0
        float inputs:clearcoatRoughness = 0
        color3f inputs:diffuseColor.connect = </World/Looks/PreviewSurfaceTexture/diffuseColorTex.outputs:rgb>
        float inputs:displacement = 0
        color3f inputs:emissiveColor = (0, 0, 0)
        float inputs:ior = 1.5
        color3f inputs:metallic.connect = </World/Looks/PreviewSurfaceTexture/metallicTex.outputs:rgb>
        normal3f inputs:normal.connect = </World/Looks/PreviewSurfaceTexture/normalTex.outputs:rgb>
        float inputs:occlusion = 1
        float inputs:opacity = 1
        float inputs:opacityThreshold = 0
        color3f inputs:roughness.connect = </World/Looks/PreviewSurfaceTexture/roughnessTex.outputs:rgb>
        color3f inputs:specularColor = (0, 0, 0)
        int inputs:useSpecularWorkflow = 0
    def Shader "diffuseColorTex"
        uniform token info:id = "UsdUVTexture"
        color3f outputs:rgb
    def Shader "metallicTex"
        color3f outputs:rgb
    def Shader "roughnessTex"
        color3f outputs:rgb
    def Shader "normalTex"
        color3f outputs:rgb
There are two problems.
  • UsdPrimvarReader_float2 is not specified
  • metallic/roughness map is not accepted in rgb (Received in float)
Below are the specifications for TextureReader.
https://graphics.pixar.com/usd/release/spec_usdpreviewsurface.html#texture-reader
If the UV of the mesh is set to “st”,the following is the description according to the UsdPreviewSurface specification.
    token inputs:frame:stPrimvarName = "st"
    def Shader "stReader"
        uniform token info:id = "UsdPrimvarReader_float2"
        token inputs:varname.connect = </World/Looks/PreviewSurfaceTexture.inputs:frame:stPrimvarName>
        float2 outputs:result
        float2 inputs:st.connect = </World/Looks/PreviewSurfaceTexture/stReader.outputs:result>
        color3f outputs:rgb
When creating a mesh with Omniverse Create, the default UV is specified with “st”, so the preset Create UsdPreviewSurface Texture may be “st”.
“UsdPrimvarReader_float2” is added, and UsdUVTexture connects UsdPrimvarReader_float2 to trace UVs.
If you do not do this, Pixar Storm and USDView will not reflect the textures.
metallic and roughness should be received in float.
One element is taken from the rgb, as in “outputs:r”.
        float inputs:metallic.connect = </World/Looks/PreviewSurfaceTexture/metallicTex.outputs:r>
        float inputs:roughness.connect = </World/Looks/PreviewSurfaceTexture/roughnessTex.outputs:r>
        float outputs:r
        float outputs:r
UsdPreviewSurface may be written as follows to get closer to a better result.
I have created a sample usda file.
create_UsdPreviewSurface_texture.usda (8.4 KB)
Check Environment
  • OS : Windows 10
  • Omniverse Create 2022.2.1
Thank you @ft-lab for the very detailed write-up. I am able to reproduce these issues. I have created a new ticket for the dev team: OM-63158
Improvements to UsdPreviewSurface to bring it inline with the specification will be available in the next major release.
Oh, I have been waiting for this. Thank you very much!
