When accessing multiple non-existent cameras, the system will crash
When I access two or more non-existent cameras, the system crashes.
I have seen many such posts on the forum.
I saw many similar posts on the forum.Here are two examples, my system crash log is almost identical to theirs.Here’s a post to find the root cause.
Firstly, the code I used for testing comes from GitHub。
Copy the program and compile it into an a.out file.
The script used during testing is as follows.I am testing two cameras here.If you want to modify more cameras, please change the 1 in $(seq 0 1) to a larger value
#!/bin/bash
for ((count=1; count<=30000; count++)); do
echo “Executing iteration $count”
for i in $(seq 0 1); do
./a.out -d /dev/video$i &
done
wait # 等待所有后台任务完成
done
hello zhang.pei.xing,
may I know which Jetpack public release version you’re working with?
I use JP6.2
there’re fixes..
Topic 337341, Add semaphore to avoid multi-cam race condition
Topic 337609, Memory leakage fix with error recovery
anyways.. it seems like application level issue.
it should report no device or cannot access if you trying to access to non-existent camera, right?
hi jerryChang:
After debugging, I found that this is not an application layer issue, but a concurrency problem related to the rtcpu and kernel.
I added the following print in the kernel to assist me in locating the issue.
diff --git a/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c b/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c
index 0b9f1e8..3f61c1c 100644
--- a/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c
+++ b/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c
@@ -288,7 +288,7 @@ static void vi_capture_ivc_status_callback(
 	struct vi_capture *capture = (struct vi_capture *)pcontext;
 	struct tegra_vi_channel *chan = capture->vi_channel;
 	uint32_t buffer_index;
+	//printk("%s", __func__);
 	if (unlikely(capture == NULL)) {
 		dev_err(chan->dev, "%s: invalid context", __func__);
 		return;
@@ -419,7 +419,8 @@ static void vi_capture_ivc_control_callback(
 		dev_err(chan->dev, "%s: invalid response", __func__);
 		return;
+	printk("%s  icontrol_msg->header.channel_id=%d control_msg->channel_setup_resp.channel_id=%d ",__func__,control_msg->header.channel_id,control_msg->channel_setup_resp.channel_id);
 	switch (control_msg->header.msg_id) {
 	case CAPTURE_CHANNEL_SETUP_RESP:
 	case CAPTURE_CHANNEL_RESET_RESP:
diff --git a/drivers/media/platform/tegra/camera/vi/vi5_fops.c b/drivers/media/platform/tegra/camera/vi/vi5_fops.c
index d03b9b7..2ca5b52 100644
--- a/drivers/media/platform/tegra/camera/vi/vi5_fops.c
+++ b/drivers/media/platform/tegra/camera/vi/vi5_fops.c
@@ -268,7 +268,7 @@ static int vi5_channel_open(struct tegra_channel *chan, u32 vi_port)
 	while (!found) {
 		sprintf(chanFilePath, "%s%u", VI_CHANNEL_DEV, channel);
+        printk(" %s  try open   /dev/capture-vi-channel%d ",__func__, channel);
 		filp = filp_open(chanFilePath, O_RDONLY, 0);
 		if (IS_ERR(filp)) {
diff --git a/drivers/platform/tegra/rtcpu/capture-ivc.c b/drivers/platform/tegra/rtcpu/capture-ivc.c
index 14e1ba3..30c4fae 100644
--- a/drivers/platform/tegra/rtcpu/capture-ivc.c
+++ b/drivers/platform/tegra/rtcpu/capture-ivc.c
@@ -154,7 +154,7 @@ int tegra_capture_ivc_register_control_cb(
 	*trans_id = (uint32_t)ctx_id;
 	cb_ctx->cb_func = control_resp_cb;
 	cb_ctx->priv_context = priv_context;
+     printk("%s   trans_id=%d ", __func__,*trans_id);
 	mutex_unlock(&civc->cb_ctx_lock);
 	return 0;
@@ -181,7 +181,7 @@ int tegra_capture_ivc_notify_chan_id(uint32_t chan_id, uint32_t trans_id)
 	chan_id  = array_index_nospec(chan_id,  NUM_CAPTURE_CHANNELS);
 	trans_id = array_index_nospec(trans_id, TOTAL_CHANNELS);
+     printk("%s  chan_id=%d  trans_id=%d ", __func__,chan_id,trans_id);
 	civc = __scivc_control;
 	mutex_lock(&civc->cb_ctx_lock);
@@ -231,7 +231,7 @@ int tegra_capture_ivc_register_capture_cb(
 			"invalid channel id %u", chan_id))
 		return -EINVAL;
 	if (!__scivc_capture)
 		return -ENODEV;
@@ -248,7 +248,7 @@ int tegra_capture_ivc_register_capture_cb(
 		ret = -EBUSY;
 		goto fail;
+    printk("%s  chan_id=%d", __func__,chan_id);
 	civc->cb_ctx[chan_id].cb_func = capture_status_ind_cb;
 	civc->cb_ctx[chan_id].priv_context = priv_context;
@@ -273,7 +273,7 @@ int tegra_capture_ivc_unregister_control_cb(uint32_t id)
 		return -ENODEV;
 	id = array_index_nospec(id, TOTAL_CHANNELS);
+    printk("%s  id=%d", __func__,id);
@@ -309,7 +309,7 @@ EXPORT_SYMBOL(tegra_capture_ivc_unregister_control_cb);
 int tegra_capture_ivc_unregister_capture_cb(uint32_t chan_id)
 	struct tegra_capture_ivc *civc;
+    printk("%s   chan_id=%d    line =%d", __func__,chan_id,__LINE__);
 	if (chan_id >= NUM_CAPTURE_CHANNELS)
 		return -EINVAL;
@@ -317,7 +317,6 @@ int tegra_capture_ivc_unregister_capture_cb(uint32_t chan_id)
 		return -ENODEV;
 	civc = __scivc_capture;
@@ -380,7 +379,7 @@ static inline void tegra_capture_ivc_recv(struct tegra_capture_ivc *civc)
 		id = hdr->channel_id;
 		trace_capture_ivc_recv(dev_name(dev), hdr->msg_id, id);
+        //printk("%s  hdr->channel_id=%d", __func__,hdr->channel_id);
 		/* Check if message is valid */
 		if (id < TOTAL_CHANNELS) {
@@ -437,7 +436,7 @@ static int tegra_capture_ivc_probe(struct tegra_ivc_channel *chan)
 	const char *service;
 	int ret;
 	uint32_t i;
+    printk("%s->%d" , __func__, __LINE__);
 	civc = devm_kzalloc(dev, (sizeof(*civc)), GFP_KERNEL);
 	if (unlikely(civc == NULL))
 		return -ENOMEM;
Then I will discuss this issue from three aspects.
The three aspects are: normal one-way access to non-existent cameras, three-way interval of 0.5 seconds access to non-existent cameras, and two-way concurrent access to non-existent cameras.
Through these three experiments, I have roughly understood the cause of the problem.
Firstly, the first experiment. Normal access to non-existent cameras.
Execute the following instructions.
v4l2-ctl -V --set-fmt-video=width=1280,height=720,pixelformat=‘YUYV’ --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100000 -d /dev/video0
The relevant log name is dmesg_one_camera.log.
dmesg_one_camera.log (104.7 KB)
The value of icontrol_rsg ->header.channel_id and the value of controll_rsg ->channel_detup-nesp.channel_id are normally equal.
Next is the second experiment.
The executed script is as follows, accessing three non-existent cameras every 0.5 seconds.
#!/bin/bash
echo "Executing iteration $count"
v4l2-ctl -V --set-fmt-video=width=1280,height=720,pixelformat='YUYV' --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100000 -d /dev/video0 &
sleep 0.5
v4l2-ctl -V --set-fmt-video=width=1280,height=720,pixelformat='YUYV' --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100000 -d /dev/video1 &
sleep 0.5
v4l2-ctl -V --set-fmt-video=width=1280,height=720,pixelformat='YUYV' --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100000 -d /dev/video2 &
done
wait # 等待所有后台任务完成
done
The log name is dmesg_three_0.5s.log.
dmesg_three_0.5s.log (398.1 KB)
It can be seen that the controllability msg ->channel_detup resp. channel_id returned by rtcpu is the icontrol_masg ->header. channel_id of the ivc sent by rtcpu last time.
Then comes the final experiment.
#!/bin/bash
done
wait # 等待所有后台任务完成
done
The relevant pstore is pstore_two_camera.zip.
pstore_two_camera.zip (44.0 KB)
It can be seen that when an error occurs, the value of channel_detup_resp. channel_id=0 is incorrect and returns the channel_id of another thread.
At this point, an incorrect channel id can lead to a series of errors, ultimately resulting in a restart.
In conclusion, when the following execution flow occurs, it is easy to encounter problems.
kthread-A Kthread-B
err = vi_capture_ivc_send_control(chan, &control_desc, sizeof(control_desc), CAPTURE_CHANNEL_RELEASE_RESP);
err = tegra_capture_ivc_register_control_cb( &vi_capture_ivc_control_callback, &transaction, capture);
err = vi_capture_ivc_send_control(chan, &control_desc, sizeof(control_desc), CAPTURE_CHANNEL_SETUP_RESP);
So the problem is that the channel id is not updated in a timely manner when the kernel interacts with the RTC and RTCPU through IVC. If the kernel threads for capturing images from multiple cameras enter recovery at the same time, problems are likely to occur.
The method mentioned in Topic 337341 only waits for the release of resources when there is a channel id error, but in extreme cases, if resources are not obtained within 120ms, it may also lead to a series of problems in the future, ultimately resulting in a restart.
So to fundamentally solve this problem, it is necessary to ensure that the channel id returned by the rtcpu is correct.
As for the issue of restarting, I will provide a description here.
When tegra_channel_ error recover fails, an incorrect value will be returned.
If the value tegra_channel_crror_recovery returns an incorrect value, tegra_channel_kthread_capture_dequeue will exit the while loop directly, and the kernel thread will end.
However, if the image retrieval application fails to retrieve the image, it will usually perform the xioctl (fd, VIDIOC_Stream OFF,&type) operation.This ioctl will call the underlying vi5_channel_stop_steaming.In vi5_channel_stop_steaming, there will be the function vi5_channel_stop_kthreads.
Kthread_stop in vi5_channel_stop_kthreads (chan ->kthread_capture_dequeue); If a stopped thread is stopped, it will cause a crash.
I disassembled the code for refcountw_arn_staturate and found that the error was’ addition on 0 '; use-after-free.
Stopping a thread that has already been released will result in a restart.
could you please also test with this patch, which should avoid such race condition.
for instance, 3fb1f9b.diff (3.7 KB)
hi jerryCHANG:
I used your 3fb1f9b. diff patch, but it still crashes.
Below is my restart log.
pstore.zip (29.2 KB)
I think we should find a way to modify the code related to RTCPU to ensure that the channel id returned by RTCPU is correct.
please give it a try to reset capture_reqs_enqueued.
diff --git a/drivers/media/platform/tegra/camera/vi/channel.c
@@ -515,6 +515,7 @@ void tegra_channel_init_ring_buffer(struct tegra_channel *chan)
        chan->capture_descr_index = 0;
        chan->capture_descr_sequence = 0;
        chan->queue_error = false;
+       chan->capture_reqs_enqueued = 0;
 EXPORT_SYMBOL(tegra_channel_init_ring_buffer);
hi jerrychang:
I added this line chan ->capture_deqs-enqueued=0; It will still crash.
please apply the attached debug patch (both on rce-fw and Linux kernel) to dig into this
for instance, Topic343830_Sep15.zip (251.6 KB)
hi jerry chang:
I obtained information from other internal sources and communicated with your developers. The root cause of the problem and the solution have been identified. Please ask internally, it should be a common issue with all Jetson products’ cameras, including the latest Thor.
