It’s for rootfs (not for bootloader), so retry count is 3.
Reproduction sequence:
- Flash jetpack with rootfs A/B enabled, unified A/B disabled.
- Boot on the A slot, dump slots info with
nvbootctrl
:Current rootfs slot: A
Active rootfs slot: A
Retry count: 3
Slot 0 update status: Boot succeeded.
Slot 0 update mode: Normal.
Slot 1 update status: Boot succeeded.
Slot 1 update mode: Normal.
- Mark slot B as active and boot failed:
# nvbootctrl -t rootfs set-slot-as-unbootable 1
# nvbootctrl -t rootfs set-active-boot-slot 1
# nvbootctrl -t rootfs dump-slots-info
Active rootfs slot: B
Retry count: 3
Slot 1 update status: Boot failed.
- Reboot the system.
- Dump slot info:
Current rootfs slot: B
Retry count: 3
- Reboot the system few more times, dump the slot info.
Result: retry count is not decremented, any reboots boot into slot B. If slot B has an invalid/corrupted/errorneous version of the software, device will not recover by itself.
UART logs:
98] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.206] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0000.212] I> Boot-mode: Coldboot
[0000.215] I> Chip revision : A02P
[0000.218] I> Bootrom patch version : 15 (correctly patched)
[0000.223] I> ATE fuse revision : 0x200
[0000.227] I> Ram repair fuse : 0x0
[0000.230] I> Ram Code : 0x2
[0000.232] I> rst_source : 0x0
[0000.235] I> rst_level : 0x0
[0000.238] I> Boot-device: eMMC
[0000.253] I> sdmmc DDR50 mode
[0000.258] I> Active Boot chain : 0
[0000.261] I> Boot-device: eMMC
[0000.264] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.272] I> Temperature = 31500
[0000.275] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.280] W> Skipping boost for clk: BPMP_APB
[0000.284] W> Skipping boost for clk: AXI_CBB
[0000.288] W> Skipping boost for clk: AON_CPU_NIC
[0000.292] W> Skipping boost for clk: CAN1
[0000.296] W> Skipping boost for clk: CAN2
[0000.300] I> Boot-device: eMMC
[0000.303] I> Boot-device: eMMC
[0000.312] I> Sdmmc: HS400 mode enabled
[0000.317] I> ECC region[0]: Start:0x0, End:0x0
[0000.321] I> ECC region[1]: Start:0x0, End:0x0
[0000.325] I> ECC region[2]: Start:0x0, End:0x0
[0000.329] I> ECC region[3]: Start:0x0, End:0x0
[0000.333] I> ECC region[4]: Start:0x0, End:0x0
[0000.337] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.343] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.347] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.352] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.356] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.362] E> FAILED: Thermal config
[0000.369] E> FAILED: MEMIO rail config
[0000.387] I> Boot-device: eMMC
[0000.397] I> sdmmc bdev is already initialized
[0000.471] I> MB1 done
����main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.480] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-938a8cd8)
[0000.480] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.481] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.481] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.487] W> device prod register failed
[0000.491] I> Boot-device: eMMC
[0000.494] I> Boot_device: SDMMC_BOOT instance: 3
[0000.500] I> sdmmc-3 params source = boot args
[0000.503] I> sdmmc bdev is already initialized
[0000.507] I> sdmmc-3 params source = boot args
[0000.515] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.522] I> Found 45 partitions in SDMMC_USER (instance 3)
[0000.523] I> Active Boot chain : 0
[0000.526] I> parsing oem signed section of bpmp-fw header done
[0000.531] I> bpmp-fw binary init read from storage
[0000.536] I> oem authentication of bpmp-fw header done
[0000.543] I> bpmp-fw binary done read from storage
[0000.545] I> bpmp-fw: Authentication init Done
[0000.550] I> parsing oem signed section of cpubl header done
[0000.555] I> cpubl binary init read from storage
[0000.560] I> bpmp-fw: Authentication Finalize Done
[0000.565] I> oem authentication of cpubl header done
[0000.569] I> cpubl binary done read from storage
[0000.574] I> cpubl: Authentication init Done
[0000.578] I> parsing oem signed section of rce header done
[0000.583] I> rce binary init read from storage
[0000.588] I> Relocating BR-BCT
[0000.590] I> cpubl: Authentication Finalize Done
[0000.595] I> oem authentication of rce header done
[0000.599] I> rce binary done read from storage
[0000.604] I> rce: Authentication init Done
[0000.608] I> parsing oem signed section of ape header done
[0000.613] I> ape binary init read from storage
[0000.617] I> rce: Authentication Finalize Done
[0000.622] I> oem authentication of ape header done
[0000.626] I> ape binary done read from storage
[0000.630] I> ape: Authentication init Done
[0000.636] I> parsing oem signed section of tos header done
[0000.640] I> tos binary init read from storage
[0000.644] I> ape: Authentication Finalize Done
[0000.649] I> oem authentication of tos header done
[0000.653] I> tos binary done read from storage
[0000.657] I> tos: Authentication init Done
[0000.663] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.667] I> bpmp-fw-dtb binary init read from storage
[0000.672] I> tos: Authentication Finalize Done
[0000.678] I> oem authentication of bpmp-fw-dtb header done
[0000.685] I> bpmp-fw-dtb binary done read from storage
[0000.687] I> bpmp-fw-dtb: Authentication init Done
[0000.693] I> parsing oem signed section of cpubl-dtb header done
[0000.697] I> cpubl-dtb binary init read from storage
[0000.702] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.740] I> oem authentication of cpubl-dtb header done
[0000.741] I> cpubl-dtb binary done read from storage
[0000.741] I> cpubl-dtb: Authentication init Done
[0000.743] I> parsing oem signed section of eks header done
[0000.744] I> eks binary init read from storage
[0000.744] I> cpubl-dtb: Authentication Finalize Done
[0000.745] I> oem authentication of eks header done
[0000.749] I> eks binary done read from storage
[0000.753] I> eks: Authentication init Done
[0000.757] I> eks: Authentication Finalize Done
[0000.761] I> EKB detected (length: 0x410) @ VA:0x52700400
��NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:15:32, Jul 26 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 315: key_mgnt_processing .......
hwkey-agent: 223: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
��mrq initialized
��[0001.265] I> Welcome to Cboot
��fmon_post initialized
��[0001.265] I> Cboot Version: t194-cfa2bc91
[0001.266] I> CPU-BL Params @ 0xf2820000
[0001.266] I> 0) Base:0x00000000 Size:0x00000000
[0001.270] I> 1) Base:0xf1100000 Size:0x00100000
[0001.274] I> 2) Base:0xf2000000 Size:0x00200000
[0001.279] I> 3) Base:0xf1200000 Size:0x00200000
��clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
��[0001.283] I> 4) Base:0xf1000000 Size:0x00100000
[0001.362] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.367] I> 6) Base:0xf3800000 Size:0x00400000
[0001.371] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.376] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.380] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.385] I> 10) Base:0xf3000000 Size:0x00800000
[0001.389] I> 11) Base:0x40000000 Size:0x00040000
[0001.394] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.398] I> 13) Base:0x40046000 Size:0x00002000
[0001.403] I> 14) Base:0x40048000 Size:0x00002000
��emc_debugfs initialized
dvs_debugfs initialized
��[0001.407] I> 15) Base:0xac000000 Size:0x00004000
[0001.416] I> 16) Base:0x4004a000 Size:0x00002000
��fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ��[0001.421] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.471] I> 18) Base:0x4004c000 Size:0x00002000
[0001.476] I> 19) Base:0xf2200000 Size:0x00600000
[0001.480] I> 20) Base:0x4004e000 Size:0x00002000
[0001.485] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.489] I> 22) Base:0x00000000 Size:0x00000000
[0001.494] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.498] I> 24) Base:0xf6000000 Size:0x02000000
[0001.502] I> 25) Base:0x40050000 Size:0x00002000
[0001.507] I> 26) Base:0x40040000 Size:0x00006000
[0001.511] I> 27) Base:0xf1800000 Size:0x00400000
[0001.516] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.520] I> 29) Base:0xf1400000 Size:0x00400000
[0001.525] I> 30) Base:0x00000000 Size:0x00000000
[0001.529] I> 31) Base:0x00000000 Size:0x00000000
[0001.534] I> 32) Base:0xf8000000 Size:0x08000000
[0001.538] I> 33) Base:0x00000000 Size:0x00000000
[0001.543] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.547] I> 35) Base:0xab000000 Size:0x01000000
[0001.552] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.556] I> 37) Base:0xf2800000 Size:0x00800000
[0001.560] I> 38) Base:0x80000000 Size:0x20000000
[0001.565] I> 39) Base:0xb0000000 Size:0x08000000
[0001.569] I> 40) Base:0x00000000 Size:0x00000000
[0001.574] I> 41) Base:0x00000000 Size:0x00000000
[0001.578] I> 42) Base:0x00000000 Size:0x00000000
[0001.583] I> 43) Base:0x00000000 Size:0x00000000
[0001.587] I> 44) Base:0x00000000 Size:0x00000000
[0001.592] I> 45) Base:0x00000000 Size:0x00000000
[0001.596] GIC-SPI Target CPU: 0
[0001.599] Interrupts Init done
[0001.602] calling constructors
[0001.605] initializing heap
[0001.608] I> Heap: [0xa0699b80 ... 0xab000000]
[0001.612] initializing threads
[0001.615] initializing timers
[0001.618] creating bootstrap completion thread
[0001.622] top of bootstrap2()
[0001.625] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.629] initializing platform
[0001.632] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.638] W> device prod register failed
[0001.641] I> Bl_dtb @0xaaf00000
[0001.648] W> "plugin-manager" doesn't exist, creating
[0001.649] W> "ids" doesn't exist, creating
[0001.654] W> "connection" doesn't exist, creating
[0001.658] W> "configs" doesn't exist, creating
[0001.674] E> failed to read label property for node 227172: 13
[0001.677] E> failed to read reg property for node 227260: 13
[0001.679] E> failed to read label property for node 227312: 13
[0001.681] E> failed to read label property for node 227380: 13
[0001.686] E> failed to read label property for node 227416: 13
[0001.692] E> failed to read label property for node 227452: 13
[0001.697] E> failed to read reg property for node 227520: 13
[0001.703] E> failed to read label property for node 227572: 13
[0001.709] I> Find /i2c@3160000's alias i2c0
[0001.711] I> Reading eeprom i2c=0 address=0x50
[0001.741] I> Device at /i2c@3160000:0x50
[0001.741] I> Reading eeprom i2c=0 address=0x56
[0001.765] I> Device at /i2c@3160000:0x56
[0001.767] I> Find /i2c@3180000's alias i2c2
[0001.767] I> Reading eeprom i2c=2 address=0x54
[0001.769] E> I2C: slave not found in slaves.
[0001.769] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.770] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.770] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.780] E> eeprom: Failed to read I2C slave device
[0001.784] I> Eeprom read failed 0x3526070d
[0001.788] I> Reading eeprom i2c=2 address=0x57
[0001.793] E> I2C: slave not found in slaves.
[0001.797] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.805] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.810] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.820] E> eeprom: Failed to read I2C slave device
[0001.824] I> Eeprom read failed 0x3526070d
[0001.828] I> Reading eeprom i2c=2 address=0x52
[0001.833] E> I2C: slave not found in slaves.
[0001.837] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.845] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.850] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.860] E> eeprom: Failed to read I2C slave device
[0001.864] I> Eeprom read failed 0x3526070d
[0001.869] I> Find /i2c@c240000's alias i2c1
[0001.872] I> Reading eeprom i2c=1 address=0x52
[0001.878] E> I2C: slave not found in slaves.
[0001.881] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.889] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.894] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.904] E> eeprom: Retry to read I2C slave device.
[0001.909] E> I2C: slave not found in slaves.
[0001.913] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.921] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.926] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.936] E> eeprom: Failed to read I2C slave device
[0001.940] I> Eeprom read failed 0x3526070d
[0001.944] I> Reading eeprom i2c=1 address=0x50
[0001.949] E> I2C: slave not found in slaves.
[0001.953] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.961] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.966] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.976] E> eeprom: Retry to read I2C slave device.
[0001.981] E> I2C: slave not found in slaves.
[0001.985] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.993] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.998] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.008] E> eeprom: Failed to read I2C slave device
[0002.012] I> Eeprom read failed 0x3526070d
[0002.016] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.021] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.032] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.038] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.049] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.057] W> "i2c@3160000" doesn't exist, creating
[0002.060] W> "module@0x50" doesn't exist, creating
[0002.065] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.072] W> "module@0x56" doesn't exist, creating
[0002.078] I> Adding plugin-manager/cvm
[0002.081] W> "chip-id" doesn't exist, creating
[0002.084] I> Adding plugin-manager/chip-id/A02P
[0002.089] I> Plugin-manager override starting
[0002.094] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.103] I> node /plugin-manager/fragement-soft-wdt matches
[0002.111] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.115] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.126] I> Disable plugin-manager status in FDT
[0002.126] I> Plugin-manager override finished successfully
[0002.127] I> gpio framework initialized
[0002.131] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.138] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.145] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.152] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.160] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.167] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.173] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.180] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.188] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.194] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.202] I> fixed regulator driver initialized
[0002.215] I> register 'maxim' power off handle
[0002.216] I> virtual i2c enabled
[0002.216] I> registered 'maxim,max20024' pmic
[0002.217] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.223] I> Boot-device: eMMC
[0002.226] I> Boot_device: SDMMC_BOOT instance: 3
[0002.235] I> sdmmc-3 params source = boot args
[0002.235] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.240] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.251] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.256] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.267] I> sdmmc bdev is already initialized
[0002.271] I> sdmmc-3 params source = boot args
[0002.302] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.315] I> Found 45 partitions in SDMMC_USER (instance 3)
[0002.326] I> enabling 'vdd-hdmi-5v0' regulator
[0002.332] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.332] I> hdmi cable connected
[0002.335] W> set volts not configured for 'vdd-1v0'
[0002.337] W> set volts not configured for 'vdd-1v8-hs'
[0002.338] I> retrieved tmds range from prod_list_hdmi_soc
[0002.342] E> invalid display type
[0002.347] E> invalid display type
[0002.348] E> cannot find any other nvdisp nodes
[0002.363] I> edid read success
[0002.376] I> edid read success
[0002.376] I> width = 640, height = 480, frequency = 25174825
[0002.377] I> width = 1920, height = 1080, frequency = 148500000
[0002.378] I> width = 1920, height = 1080, frequency = 148351648
[0002.382] I> width = 1280, height = 720, frequency = 74175824
[0002.388] I> width = 720, height = 480, frequency = 26973026
[0002.393] I> width = 720, height = 480, frequency = 26973026
[0002.399] I> width = 640, height = 480, frequency = 25174825
[0002.404] I> width = 1920, height = 1080, frequency = 148351648
[0002.410] I> width = 720, height = 576, frequency = 26973026
[0002.415] I> width = 1280, height = 720, frequency = 74175824
[0002.421] I> width = 1920, height = 1080, frequency = 74175824
[0002.427] I> width = 720, height = 576, frequency = 26973026
[0002.432] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.442] I> hdmi_enable, starting HDMI initialisation
[0002.447] I> hdmi_enable, HDMI initialisation complete
[0002.457] I> Load in CBoot Boot Options partition and parse it
[0002.464] E> Error -9 when finding node with path /boot-configuration
[0002.464] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.468] I> Using default boot order
[0002.471] I> boot-dev-order :-
[0002.474] I> 1.sd
[0002.476] I> 2.usb
[0002.478] I> 3.nvme
[0002.480] I> 4.emmc
[0002.481] I> 5.net
[0002.483] I> Hit any key to stop autoboot: 4 3 2 1
[0004.491] initializing target
[0004.491] calling apps_init()
[0004.492] starting app kernel_boot_app
[0004.511] I> found decompressor handler: lz4-legacy
[0004.512] I> decompressing BMP blob ...
[0004.523] I> Kernel type = Normal
[0004.523] I> ########## SD (0) boot ##########
[0004.524] I> No sdcard
[0004.524] I> -0 params source =
[0004.524] E> Blockdev open: exit error
[0004.524] E> SD boot failed, err: 724238353
[0004.525] I> ########## USB (0) boot ##########
[0004.536] I> Validate XUSB-FW ...
[0004.536] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.538] I> Encryption fuse is not ON
[0004.539] I> USB Firmware Version: 60.09 release
[0004.596] I> regulator of usb2-0 already enabled
[0004.604] I> regulator of usb2-1 already enabled
[0004.612] I> regulator of usb2-2 already enabled
[0004.622] I> enabling 'vdd-5v-sata' regulator
[0005.691] I> USB 2.0 port 4 new low-speed USB device detected
[0005.692] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa4ad2000, cmd_ring.dma = 0xa4ad20c0
[0005.793] I> Start to enumerate device
[0005.794] W> handle_command_completion_event: WARNING: Command was not successfully completed (0x11)
[0008.803] W> xusbh_wait_irq: Timed out! status = 0x00
[0011.812] W> xusbh_wait_irq: Timed out! status = 0x00
[0011.812] E> Failed to enumerate USB device
[0011.813] E> failed to start xhci controller
[0011.813] E> Error in init of XUSB host driver, err: 7979000c
[0011.813] W> Failed to initialize device 5-0
[0011.814] E> USB boot failed, err: 2037973004
[0011.814] I> ########## NVME (0) boot ##########
[0011.818] I> Initializing nvme device instance 0
[0011.823] I> Initializing nvme controller
[0011.827] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0011.833] I> vpcie3v3-supply not found
[0011.837] I> vpcie12v-supply not found
[0011.840] W> Failed to get nvidia,plat-gpios
[0011.844] I> tegrabl_pcie_soc_preinit: (0):
[0011.848] I> Unpowergate
[0011.851] I> tegrabl_car_clk_disable(0) ...
[0011.855] I> tegrabl_car_rst_set(CORE, 0) ...
[0011.859] I> tegrabl_car_rst_set(APB, 0) ...
[0011.863] I> tegrabl_car_clk_enable(0) ...
[0011.867] I> tegrabl_car_rst_clear(APB, 0) ...
[0011.871] I> tegrabl_set_ctrl_state(0)
[0011.875] I> CLR PCIE_APB:6
[0011.878] I> tegrabl_pcie_soc_init: (0):
[0011.881] I> APPL initialization ...
[0011.885] I> poweron phys
[0011.887] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0011.894] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0011.899] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0011.904] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0011.910] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0013.015] C> Failed to link up controller-0
[0013.016] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0013.016] I> Failed to initialize SoC Host PCIe controller
[0013.016] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(0); error=0x12
[0013.017] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0013.017] W> Failed to open NVME-0, err = 80800612
[0013.022] W> Failed to initialize device 10-0
[0013.026] E> NVME (0) boot failed, err: 0x80800612
[0013.031] I> ########## NVME (1) boot ##########
[0013.035] I> Initializing nvme device instance 1
[0013.040] I> Initializing nvme controller
[0013.044] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0013.050] I> vpcie3v3-supply not found
[0013.053] I> vpcie12v-supply not found
[0013.057] W> Failed to get nvidia,plat-gpios
[0013.061] I> tegrabl_pcie_soc_preinit: (1):
[0013.065] I> Unpowergate
[0013.068] I> tegrabl_car_clk_disable(1) ...
[0013.072] I> tegrabl_car_rst_set(CORE, 1) ...
[0013.076] I> tegrabl_car_rst_set(APB, 1) ...
[0013.080] I> tegrabl_car_clk_enable(1) ...
[0013.084] I> tegrabl_car_rst_clear(APB, 1) ...
[0013.088] I> tegrabl_set_ctrl_state(1)
[0013.092] I> CLR PCIE_APB:6
[0013.094] I> tegrabl_pcie_soc_init: (1):
[0013.098] I> APPL initialization ...
[0013.101] I> poweron phys
[0013.104] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14100000
[0013.110] I> tegrabl_power_on_phy: power on phy @0x3e10000
[0013.217] I> PCIe controller-1 link is up
[0013.218] I> tegra_pcie_info[1].cfg0_base = 0x30000000
[0013.218] I> tegra_pcie_info[1].cfg1_base = 0x30020000
[0013.218] I> tegra_pcie_info[1].atu_dma_base = 0x30040000
[0013.219] I> tegra_pcie_bus[1].mem = 0x30200000
[0013.219] I> Scanning busnr: 0 devfn: 0
[0013.219] I> PCIe IDs: 0x1ad210de
[0013.223] I> PCIe RID_CC: 0x60400a1
[0013.226] I> Scanning busnr: 1 devfn: 0
[0013.230] I> PCIe IDs: 0x91711b4b
[0013.233] I> PCIe RID_CC: 0x1060113
[0013.236] I> PCI Config: I/O=0x30100000, Memory=0x30200000
[0013.241] I> IO bar_num=0 bar=0x30100000
[0013.245] I> IO bar_num=1 bar=0x30100008
[0013.249] I> IO bar_num=2 bar=0x30100010
[0013.253] I> IO bar_num=3 bar=0x30100018
[0013.256] I> IO bar_num=4 bar=0x30100020
[0013.260] I> MEM bar_num=5 bar=0x30200000
[0013.264] I> Number of PCIe devices detected: 2
[0013.268] E> tegrabl_nvme_init: Failed tegrabl_pcie_get_dev(1); error=0x0
[0013.275] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0013.282] W> Failed to open NVME-1, err = 80800612
[0013.286] W> Failed to initialize device 10-1
[0013.290] E> NVME (1) boot failed, err: 0x80800612
[0013.295] I> ########## NVME (2) boot ##########
[0013.299] I> Initializing nvme device instance 2
[0013.304] I> Initializing nvme controller
[0013.308] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0013.314] I> vpcie3v3-supply not found
[0013.318] I> vpcie12v-supply not found
[0013.321] W> Failed to get nvidia,plat-gpios
[0013.325] I> tegrabl_pcie_soc_preinit: (2):
[0013.329] I> Unpowergate
[0013.332] I> tegrabl_car_clk_disable(2) ...
[0013.336] I> tegrabl_car_rst_set(CORE, 2) ...
[0013.340] I> tegrabl_car_rst_set(APB, 2) ...
[0013.344] I> tegrabl_car_clk_enable(2) ...
[0013.348] I> tegrabl_car_rst_clear(APB, 2) ...
[0013.352] I> tegrabl_set_ctrl_state(2)
[0013.356] I> CLR PCIE_APB:6
[0013.359] I> tegrabl_pcie_soc_init: (2):
[0013.362] I> APPL initialization ...
[0013.366] I> poweron phys
[0013.369] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14120000
[0013.375] I> tegrabl_power_on_phy: controller 2 not available
[0013.380] E> Failed to power on phy on controller-2
[0013.385] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0013.390] I> Failed to initialize SoC Host PCIe controller
[0013.395] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(2); error=0x1
[0013.402] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0013.408] W> Failed to open NVME-2, err = 80800601
[0013.413] W> Failed to initialize device 10-2
[0013.417] E> NVME (2) boot failed, err: 0x80800601
[0013.422] I> ########## NVME (3) boot ##########
[0013.426] I> Initializing nvme device instance 3
[0013.431] I> Initializing nvme controller
[0013.435] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0013.441] I> vpcie3v3-supply not found
[0013.444] I> vpcie12v-supply not found
[0013.448] W> Failed to get nvidia,plat-gpios
[0013.452] I> tegrabl_pcie_soc_preinit: (3):
[0013.456] I> Unpowergate
[0013.459] I> tegrabl_car_clk_disable(3) ...
[0013.463] I> tegrabl_car_rst_set(CORE, 3) ...
[0013.467] I> tegrabl_car_rst_set(APB, 3) ...
[0013.471] I> tegrabl_car_clk_enable(3) ...
[0013.475] I> tegrabl_car_rst_clear(APB, 3) ...
[0013.479] I> tegrabl_set_ctrl_state(3)
[0013.483] I> CLR PCIE_APB:6
[0013.485] I> tegrabl_pcie_soc_init: (3):
[0013.489] I> APPL initialization ...
[0013.492] I> poweron phys
[0013.495] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14140000
[0013.501] I> tegrabl_power_on_phy: power on phy @0x3e80000
[0014.607] C> Failed to link up controller-3
[0014.607] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0014.608] I> Failed to initialize SoC Host PCIe controller
[0014.608] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(3); error=0x12
[0014.609] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0014.609] W> Failed to open NVME-3, err = 80800612
[0014.614] W> Failed to initialize device 10-3
[0014.618] E> NVME (3) boot failed, err: 0x80800612
[0014.623] I> ########## NVME (4) boot ##########
[0014.627] I> Initializing nvme device instance 4
[0014.631] I> Initializing nvme controller
[0014.636] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0014.642] I> vpcie3v3-supply not found
[0014.645] I> vpcie12v-supply not found
[0014.649] W> Failed to get nvidia,plat-gpios
[0014.653] I> tegrabl_pcie_soc_preinit: (4):
[0014.657] I> Unpowergate
[0014.660] I> tegrabl_car_clk_disable(4) ...
[0014.663] I> tegrabl_car_rst_set(CORE, 4) ...
[0014.668] I> tegrabl_car_rst_set(APB, 4) ...
[0014.672] I> tegrabl_car_clk_enable(4) ...
[0014.676] I> tegrabl_car_rst_clear(APB, 4) ...
[0014.680] I> tegrabl_set_ctrl_state(4)
[0014.684] I> CLR PCIE_APB:6
[0014.686] I> tegrabl_pcie_soc_init: (4):
[0014.690] I> APPL initialization ...
[0014.693] I> poweron phys
[0014.696] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14160000
[0014.702] I> tegrabl_power_on_phy: controller 4 not available
[0014.708] E> Failed to power on phy on controller-4
[0014.713] W> Failed tegrabl_pcie_soc_init(), error=0x1
[0014.717] I> Failed to initialize SoC Host PCIe controller
[0014.723] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(4); error=0x1
[0014.729] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800601
[0014.736] W> Failed to open NVME-4, err = 80800601
[0014.740] W> Failed to initialize device 10-4
[0014.745] E> NVME (4) boot failed, err: 0x80800601
[0014.749] I> ########## NVME (5) boot ##########
[0014.754] I> Initializing nvme device instance 5
[0014.758] I> Initializing nvme controller
[0014.763] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0014.768] I> i=0, reg_phandle=0x1b
[0014.774] I> reg_voltage=3300000
[0014.775] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1b, 3300000)
[0014.787] I> enabling 'vdd-3v3-pcie' regulator
[0014.787] I> i=1, reg_phandle=0x1c
[0014.792] I> reg_voltage=1200000
[0014.793] I> tegrabl_pcie_enable_regulators: regulator_set_voltage(0x1c, 1200000)
[0014.805] I> enabling 'vdd-12v-pcie' regulator
[0014.805] I> tegrabl_pcie_soc_preinit: (5):
[0014.808] I> Unpowergate
[0014.811] I> tegrabl_car_clk_disable(5) ...
[0014.815] I> tegrabl_car_rst_set(CORE, 5) ...
[0014.819] I> tegrabl_car_rst_set(APB, 5) ...
[0014.823] I> tegrabl_car_clk_enable(5) ...
[0014.827] I> tegrabl_car_rst_clear(APB, 5) ...
[0014.831] I> tegrabl_set_ctrl_state(5)
[0014.835] I> CLR PCIE_APB:6
[0014.838] I> tegrabl_pcie_soc_init: (5):
[0014.841] I> APPL initialization ...
[0014.845] I> poweron phys
[0014.848] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x141a0000
[0014.854] I> tegrabl_power_on_phy: power on phy @0x3eb0000
[0014.859] I> tegrabl_power_on_phy: power on phy @0x3ec0000
[0014.864] I> tegrabl_power_on_phy: power on phy @0x3ed0000
[0014.870] I> tegrabl_power_on_phy: power on phy @0x3ee0000
[0014.875] I> tegrabl_power_on_phy: power on phy @0x3ef0000
[0014.880] I> tegrabl_power_on_phy: power on phy @0x3f00000
[0014.886] I> tegrabl_power_on_phy: power on phy @0x3f10000
[0014.891] I> tegrabl_power_on_phy: power on phy @0x3f20000
[0015.996] C> Failed to link up controller-5
[0015.997] W> Failed tegrabl_pcie_soc_init(), error=0x12
[0015.997] I> Failed to initialize SoC Host PCIe controller
[0015.998] E> tegrabl_nvme_init: Failed tegrabl_pcie_init(5); error=0x12
[0015.998] W> tegrabl_nvme_bdev_open: Failed NVME INIT; error=0x80800612
[0015.999] W> Failed to open NVME-5, err = 80800612
[0016.003] W> Failed to initialize device 10-5
[0016.007] E> NVME (5) boot failed, err: 0x80800612
[0016.012] I> ########## Fixed storage boot ##########
[0016.017] I> Loading kernel-bootctrl from partition
[0016.022] I> Loading partition kernel-bootctrl at 0xa4b30000 from device(0x1)
[0016.035] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0016.036] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0016.049] I> Already published: 00010003
[0016.049] I> Look for boot partition
[0016.050] I> Fallback: assuming 0th partition is boot partition
[0016.056] I> Set 1th partition is boot partition
[0016.060] I> Detect filesystem
[0016.093] I> Loading extlinux.conf ...
[0016.093] I> Loading extlinux.conf binary from rootfs ...
[0016.094] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0022.291] I> lookup_linear_dir:447: Invalid file block num
[0022.291] I> ext2_walk:142: 'boot' lookup failed
[0022.292] I> ext4_open_file:666: '/boot/extlinux/extlinux.conf' lookup failed
[0022.292] E> file /sdmmc_user/boot/extlinux/extlinux.conf open failed!!
[0022.293] W> Failed to load extlinux.conf binary from rootfs (err=202113041)
[0022.296] E> Failed to find/load /boot/extlinux/extlinux.conf
[0022.302] I> Loading kernel ...
[0022.305] I> No kernel binary path
[0022.308] I> Continue to load from partition ...
[0022.312] I> A/B: bin_type (37) slot 1
[0022.316] I> Loading kernel_b from partition
[0022.320] I> Loading partition kernel_b at 0xa4b30000 from device(0x1)
[0022.811] I> Validate kernel ...
[0022.811] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0023.229] I> Encryption fuse is not ON
[0023.260] I> Checking boot.img header magic ... [0023.260] I> [OK]
[0023.260] I> Loading kernel-dtb ...
[0023.260] I> No kernel-dtb binary path
[0023.261] I> Continue to load from partition ...
[0023.261] I> A/B: bin_type (38) slot 1
[0023.261] I> Loading kernel-dtb_b from partition
[0023.262] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x1)
[0023.275] I> Validate kernel-dtb ...
[0023.276] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0023.280] I> Encryption fuse is not ON
[0023.282] I> Kernel hdr @0xa4b30000
[0023.284] I> Kernel dtb @0x90000000
[0023.287] I> decompressor handler not found
[0023.291] I> Copying kernel image (34484232 bytes) from 0xa4b30800 to 0x80080000 ... [0023.307] I> Done
[0023.307] I> Move ramdisk (len: 11357561) from 0xa6c14000 to 0x92000000
[0023.312] I> Updated bpmp info to DTB
[0023.313] I> Ramdisk: Base: 0x92000000; Size: 0xad4d79
[0023.316] I> Updated initrd info to DTB
[0023.319] W> WARN: Fail to override "console=none" in commandline
[0023.325] I> Active rootfs suffix: _b
[0023.329] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0023.336] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0023.343] I> Active slot suffix:
[0023.346] I> add_boot_slot_suffix: slot_suffix =
[0023.351] I> Linux Cmdline: console=ttyTCU0,115200 root=UUID=4799b677-c603-408e-af20-0c111821efdd rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix=_b tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a5000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0023.394] I> Updated bootarg info to DTB
[0023.398] W> MAC addr invalid!
[0023.401] E> Failed to get WIFI MAC address
[0023.405] W> MAC addr invalid!
[0023.408] E> Failed to get Bluetooth MAC address
[0023.412] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:86:70
[0023.419] W> "plugin-manager" doesn't exist, creating
[0023.424] I> Adding /chosen/plugin-manager/cvm
[0023.428] W> "chip-id" doesn't exist, creating
[0023.432] I> Adding /chosen/plugin-manager/chip-id
[0023.437] W> "configs" doesn't exist, creating
[0023.441] I> Adding /chosen/plugin-manager/configs
[0023.445] W> "ids" doesn't exist, creating
[0023.449] I> Adding /chosen/plugin-manager/ids
[0023.454] W> "odm-data" doesn't exist, creating
[0023.458] I> Adding /chosen/plugin-manager/odm-data
[0023.467] W> "memory" doesn't exist, creating
[0023.468] I> [0] START: 0x80000000, END: 0xac000000
[0023.472] I> [1] START: 0xac004000, END: 0xf0ad0000
[0023.476] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0023.481] I> dram_block larger than 80000000
[0023.485] I> [3] START: 0x100000000, END: 0x880000000
[0023.490] I> added [base:0x80000000, size:0x2c000000] to /memory
[0023.496] I> added [base:0xac200000, size:0x44800000] to /memory
[0023.502] I> added [base:0x100000000, size:0x780000000] to /memory
[0023.509] I> Updated memory info to DTB
[0023.512] E> add_disp_param: failed to get display params for du=1
[0023.518] W> "reset" doesn't exist, creating
[0023.523] I> Adding ecid(00000001647d02832000000006fe8080) to DT
[0023.528] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0023.532] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0023.537] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0023.542] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0023.547] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0023.551] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0023.556] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0023.561] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0023.567] W> "misc-data" doesn't exist, creating
[0023.570] I> Boot-device: eMMC
[0023.573] I> Add boot-sdmmc to plugin-manager/misc-data
[0023.578] I> Add storage-sdmmc to plugin-manager/misc-data
[0023.583] W> Unknown storage device
[0023.587] I> Add serial number:1560321001713 as DT property
[0023.593] I> Plugin-manager override starting
[0023.597] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0023.604] I> node /plugin-manager/fragement-soft-wdt matches
[0023.611] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0023.616] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0023.628] I> Disable plugin-manager status in FDT
[0023.628] I> Plugin-manager override finished successfully
[0023.629] I> tegrabl_load_kernel_and_dtb: Done
[0023.652] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5497-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Jul 26 12:19:28 PDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 780000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06aa000
[ 0.000000] Found lut_mem: 00002008@a06a5000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8192517
[ 0.000000] Kernel command line: console=ttyTCU0,115200 root=UUID=4799b677-c603-408e-af20-0c111821efdd rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix=_b tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a5000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29916(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Memory: 31913264K/33290228K available (15358K kernel code, 2956K rwdata, 6692K rodata, 8640K init, 612K bss, 623300K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf20000000 ( 512 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc800000000 ( 32768 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009060] Console: colour dummy device 80x25
[ 0.012430] console [tty0] enabled
[ 0.015615] bootconsole [tegra_comb_uart0] disabled
[ 0.020879] kmemleak: Kernel memory leak detector disabled
[ 0.020915] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.020952] pid_max: default: 32768 minimum: 301
[ 0.022049] Security Framework initialized
[ 0.022618] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.022647] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.024749] ftrace: allocating 47077 entries in 184 pages
[ 0.421304] sched-energy: Sched-energy-costs installed from DT
[ 0.421365] ASID allocator initialised with 65536 entries
[ 0.460255] tegra-id: chipid=21917.
[ 0.460280] tegra-id: opt_subrevision=1.
[ 0.460321] Tegra Revision: A02p SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.460380] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.460436] DTB Build time: Jul 26 2021 12:22:25
[ 0.508465] CPU1: Booted secondary processor [4e0f0040]
[ 0.539829] CPU2: Booted secondary processor [4e0f0040]
[ 0.571883] CPU3: Booted secondary processor [4e0f0040]
[ 0.604141] CPU4: Booted secondary processor [4e0f0040]
[ 0.636262] CPU5: Booted secondary processor [4e0f0040]
[ 0.668732] CPU6: Booted secondary processor [4e0f0040]
[ 0.700638] CPU7: Booted secondary processor [4e0f0040]
[ 0.700899] Brought up 8 CPUs
[ 0.701093] SMP: Total of 8 processors activated.
[ 0.701124] CPU features: detected feature: Privileged Access Never
[ 0.701177] CPU features: detected feature: LSE atomic instructions
[ 0.701219] CPU features: detected feature: User Access Override
[ 0.701249] CPU features: detected feature: 32-bit EL0 Support
[ 0.703166] CPU: All CPU(s) started at EL2
[ 0.703248] alternatives: patching kernel code
[ 0.712429] devtmpfs: initialized
[ 0.774109] Initilizing CustomIPI irq domain
[ 0.774417] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.774470] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.785780] pinctrl core: initialized pinctrl subsystem
[ 0.786092] OS set in device tree is not L4T.
[ 0.786483] regulator-dummy: no parameters
[ 0.786839] Initializing plugin-manager
[ 0.786905] Plugin module not found
[ 0.786954] Plugin-manager status disabled
[ 0.788771] NET: Registered protocol family 16
[ 0.796686] pstore: using zlib compression
[ 0.797612] console [pstore-1] enabled
[ 0.797638] pstore: Registered ramoops as persistent store backend
[ 0.797687] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.816443] cpuidle: using governor menu
[ 0.818212] bpmp: waiting for handshake
[ 0.818245] bpmp: handshake completed
[ 0.818282] bpmp: synchronizing channels
[ 0.818308] bpmp: channels synchronized
[ 0.818329] bpmp: mail init ok
[ 0.821837] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.822114] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.822141] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.822187] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.822207] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.822228] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.822252] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.822284] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.822313] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.822335] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.822357] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.826125] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.826182] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.828911] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.831338] tegra_aon_clk_init: ok
[ 0.831373] Registering BPMP clocks...
[ 0.831495] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.832257] Serial: AMBA PL011 UART driver
[ 0.832408] tegra_powergate_init: DONE
[ 0.832552] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.832596] DTB Build time: Jul 26 2021 12:22:25
[ 0.835986] Tegra reboot handler registered.
[ 0.844672] iommu: Adding device 14180000.pcie to group 0
[ 0.845448] iommu: Adding device 14100000.pcie to group 1
[ 0.846218] iommu: Adding device 14140000.pcie to group 2
[ 0.846965] iommu: Adding device 141a0000.pcie to group 3
[ 0.848578] iommu: Adding device 2490000.ether_qos to group 4
[ 0.849149] iommu: Adding device 3100000.serial to group 5
[ 0.849796] iommu: Adding device 3110000.serial to group 6
[ 0.850258] iommu: Adding device 3140000.serial to group 7
[ 0.850961] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.851298] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.851346] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.851373] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.851392] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.851492] tegra-pmc: PMC Prod config success
[ 0.851743] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.851788] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.852205] iommu: Adding device 3460000.sdhci to group 8
[ 0.852890] iommu: Adding device 3400000.sdhci to group 9
[ 0.853592] iommu: Adding device 2450000.ufshci to group 10
[ 0.854147] iommu: Adding device 3210000.spi to group 11
[ 0.854701] iommu: Adding device c260000.spi to group 12
[ 0.855849] iommu: Adding device 3160000.i2c to group 13
[ 0.856343] iommu: Adding device c240000.i2c to group 14
[ 0.856815] iommu: Adding device 3180000.i2c to group 15
[ 0.857267] iommu: Adding device 3190000.i2c to group 16
[ 0.858014] iommu: Adding device 31b0000.i2c to group 17
[ 0.858458] iommu: Adding device 31c0000.i2c to group 18
[ 0.858907] iommu: Adding device c250000.i2c to group 19
[ 0.859602] iommu: Adding device 31e0000.i2c to group 20
[ 0.860584] iommu: Adding device sound to group 21
[ 0.861231] iommu: Adding device 3510000.hda to group 22
[ 0.861960] iommu: Adding device bc00000.rtcpu to group 23
[ 0.864311] iommu: Adding device 13e10000.host1x to group 24
[ 0.864833] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.865322] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.865829] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.866433] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.866845] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.867256] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.867712] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.868119] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.868753] iommu: Adding device 15340000.vic to group 33
[ 0.869282] iommu: Adding device 15380000.nvjpg to group 34
[ 0.869638] iommu: Adding device 15500000.tsec to group 35
[ 0.869954] iommu: Adding device 15100000.tsecb to group 36
[ 0.870270] iommu: Adding device 15480000.nvdec to group 37
[ 0.870619] iommu: Adding device 15140000.nvdec1 to group 38
[ 0.870934] iommu: Adding device 154c0000.nvenc to group 39
[ 0.871248] iommu: Adding device 15a80000.nvenc1 to group 40
[ 0.871810] iommu: Adding device 15880000.nvdla0 to group 41
[ 0.872465] iommu: Adding device 158c0000.nvdla1 to group 42
[ 0.873180] iommu: Adding device 15200000.nvdisplay to group 43
[ 0.873383] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06aa000(800000)
[ 0.873417] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a5000(3000)
[ 0.877377] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.877474] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.878082] iommu: Adding device 15210000.nvdisplay to group 44
[ 0.878171] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.878927] iommu: Adding device 15220000.nvdisplay to group 45
[ 0.878990] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.881401] iommu: Adding device 15c10000.vi to group 46
[ 0.881618] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.882078] iommu: Adding device 14800000.isp to group 47
[ 0.883160] iommu: Adding device 16000000.pva0 to group 48
[ 0.883733] iommu: Adding device 16800000.pva1 to group 49
[ 0.884301] iommu: Adding device 15810000.se to group 50
[ 0.884761] iommu: Adding device 15820000.se to group 51
[ 0.885086] iommu: Adding device 15830000.se to group 52
[ 0.885912] iommu: Adding device 15840000.se to group 53
[ 0.886263] iommu: Adding device c1a0000.aon to group 54
[ 0.888200] iommu: Adding device d000000.bpmp to group 55
[ 0.888612] bpmp: ping status is 0
[ 0.888768] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.892200] bpmp d000000.bpmp: probe ok
[ 0.894355] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.894855] iommu: Adding device smmu_test to group 56
[ 0.896092] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[ 0.896141] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[ 0.896190] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[ 0.896236] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[ 0.896279] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[ 0.896322] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[ 0.896364] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[ 0.896405] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[ 0.896461] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[ 0.896500] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[ 0.896537] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[ 0.896574] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[ 0.896612] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[ 0.896649] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[ 0.896683] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[ 0.896720] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[ 0.896757] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[ 0.896860] mc-err: mcerr ops are set to t19x
[ 0.904131] iommu: Adding device 2600000.dma to group 57
[ 0.909575] gpio gpiochip0: gpio-line-names specifies 210 line names but there are 224 lines on the chip
[ 0.910712] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.911060] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.920099] gpio gpiochip1: gpio-line-names specifies 30 line names but there are 40 lines on the chip
[ 0.920226] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.920534] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.923138] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.923166] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.923190] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.924175] iommu: Adding device 3550000.xudc to group 58
[ 0.924914] iommu: Adding device 3610000.xhci to group 59
[ 0.927272] arm64_ras arm64_ras: probed
[ 0.927747] ras_fhi_enable: FHI 479 enabled on CPU0
[ 0.927810] ras_fhi_enable: FHI 480 enabled on CPU1
[ 0.927890] ras_fhi_enable: FHI 481 enabled on CPU2
[ 0.927959] ras_fhi_enable: FHI 482 enabled on CPU3
[ 0.928022] ras_fhi_enable: FHI 483 enabled on CPU4
[ 0.928092] ras_fhi_enable: FHI 484 enabled on CPU5
[ 0.928153] ras_fhi_enable: FHI 485 enabled on CPU6
[ 0.928224] ras_fhi_enable: FHI 486 enabled on CPU7
[ 0.928434] carmel_ras_enable: RAS enabled on cpu0
[ 0.928641] carmel_ras_enable: RAS enabled on cpu1
[ 0.928879] carmel_ras_enable: RAS enabled on cpu2
[ 0.929077] carmel_ras_enable: RAS enabled on cpu3
[ 0.929296] carmel_ras_enable: RAS enabled on cpu4
[ 0.929480] carmel_ras_enable: RAS enabled on cpu5
[ 0.929681] carmel_ras_enable: RAS enabled on cpu6
[ 0.929875] carmel_ras_enable: RAS enabled on cpu7
[ 0.929973] carmel_ras carmel_ras: probed
[ 0.931459] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 0.932113] tegra-cbb c600000.aon-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 0.933222] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 0.934333] tegra-cbb be00000.rce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[ 0.935339] tegra-cbb b600000.sce-noc: noc_secure_irq = 496, noc_nonsecure_irq = 495>
[ 0.935781] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.939142] vdd-3v3-cvb: 3300 mV
[ 0.939527] vdd-1v8-cvb: 1800 mV
[ 0.940033] vdd-1v8-sd: 1800 mV
[ 0.940414] vdd-epb-1v0: 1000 mV
[ 0.940707] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.941044] vdd-sdmmc1-sw: 3300 mV
[ 0.941445] avdd-cam-2v8: 2800 mV
[ 0.941852] vdd-sata-1v5: 1500 mV
[ 0.942216] vdd-1v8-slt: 1800 mV
[ 0.942540] vdd-3v3-slt: 3300 mV
[ 0.942887] vdd-fan: 5000 mV
[ 0.943344] vdd-hdmi-5v0: 5000 mV
[ 0.943729] vdd_sys_en: 1200 mV
[ 0.944130] vdd-5v-sata: 5000 mV
[ 0.944695] vdd-3v3-pcie: 3300 mV
[ 0.945155] vdd-12v-pcie: 1200 mV
[ 0.945532] vdd-ac-bat: 5000 mV
[ 0.945773] vdd-5v-sata: supplied by vdd-ac-bat
[ 0.981638] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.986633] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.987038] SCSI subsystem initialized
[ 0.987563] usbcore: registered new interface driver usbfs
[ 0.987674] usbcore: registered new interface driver hub
[ 0.987779] usbcore: registered new device driver usb
[ 0.999071] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.002148] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.013093] vdd-1v0: at 1000 mV
[ 1.021113] vdd-1v8-hs: at 1800 mV
[ 1.029138] vdd-1v8-ls: at 1800 mV
[ 1.037164] vdd-1v8-ao: at 1800 mV
[ 1.045234] vddio-ddr-1v1: at 1100 mV
[ 1.053004] vdd-rtc: at 800 mV
[ 1.054350] spmic-ldo1: at 2375 mV
[ 1.065014] vdd-ao-3v3: at 3300 mV
[ 1.077052] vddio-emmc-3v3: at 3300 mV
[ 1.078529] spmic-ldo4: at 1587 mV
[ 1.089117] vdd-usb-3v3: at 3300 mV
[ 1.101125] vddio-sdmmc1-3v3: at 3300 mV
[ 1.109151] vdd-csi-1v2: at 1200 mV
[ 1.110767] spmic-ldo8: at 1800 mV
[ 1.115928] GPIO line 246 (gpio_default) hogged as output/high
[ 1.117361] GPIO line 247 (gpio_default) hogged as output/high
[ 1.117779] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.118208] max77620 4-003c: max77620 probe successful
[ 1.119036] media: Linux media interface: v0.10
[ 1.119161] Linux video capture interface: v2.00
[ 1.120861] pps_core: LinuxPPS API ver. 1 registered
[ 1.120884] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.120980] PTP clock support registered
[ 1.121284] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 1.121650] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.121703] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.124561] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 1.124649] trusty trusty: selected api version: 3 (requested 3)
[ 1.125808] Advanced Linux Sound Architecture Driver Initialized.
[ 1.126428] Bluetooth: Core ver 2.22
[ 1.126526] NET: Registered protocol family 31
[ 1.126545] Bluetooth: HCI device and connection manager initialized
[ 1.126572] Bluetooth: HCI socket layer initialized
[ 1.126597] Bluetooth: L2CAP socket layer initialized
[ 1.126636] Bluetooth: SCO socket layer initialized
[ 1.129442] camchar: rtcpu character device driver loaded
[ 1.132383] clocksource: Switched to clocksource arch_sys_counter
[ 1.176560] VFS: Disk quotas dquot_6.6.0
[ 1.176692] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.177099] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.178576] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.178662] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.178946] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.178971] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.179001] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.179027] nvmap_page_pool_init: Total RAM pages: 8166732
[ 1.179047] nvmap_page_pool_init: nvmap page pool size: 1020841 pages (3987 MB)
[ 1.179375] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.179770] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.181717] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.195026] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.195377] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.195722] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.195952] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.196185] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.196362] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 1.196548] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.197765] la/ptsa driver initialized.
[ 1.198154] NET: Registered protocol family 2
[ 1.199102] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 1.200420] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.201040] TCP: Hash tables configured (established 262144 bind 65536)
[ 1.201104] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.201561] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 1.202384] NET: Registered protocol family 1
[ 1.202948] RPC: Registered named UNIX socket transport module.
[ 1.202971] RPC: Registered udp transport module.
[ 1.202990] RPC: Registered tcp transport module.
[ 1.203008] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.203246] Trying to unpack rootfs image as initramfs...
[ 1.524168] Freeing initrd memory: 11088K
[ 1.544146] random: fast init done
[ 1.548203] host1x 13e10000.host1x: initialized
[ 1.551345] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.557021] audit: initializing netlink subsys (disabled)
[ 1.557085] audit: type=2000 audit(1.164:1): initialized
[ 1.557833] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.568685] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.570083] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.570835] 9p: Installing v9fs 9p2000 file system support
[ 1.575899] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.576054] io scheduler noop registered
[ 1.576310] io scheduler cfq registered (default)
[ 1.580176] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.614716] iommu: Adding device 2993000.adsp to group 60
[ 1.729434] iommu: Adding device aconnect@2a41000:adsp_audio to group 61
[ 1.730435] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.743533] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.744007] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.744668] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.745138] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.748183] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.748455] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.748488] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 1.751702] tsec 15500000.tsec: initialized
[ 1.753502] tsec 15100000.tsecb: initialized
[ 1.757825] nvdec 15480000.nvdec: initialized
[ 1.760640] nvdec 15140000.nvdec1: initialized
[ 1.767501] falcon 15340000.vic: initialized
[ 1.769520] falcon 15380000.nvjpg: initialized
[ 1.771332] falcon 154c0000.nvenc: initialized
[ 1.773415] falcon 15a80000.nvenc1: initialized
[ 1.776716] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.779434] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.780998] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.782483] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.783879] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.785447] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.786929] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.788430] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.792004] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.797488] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.797904] scare-pigeon 14b00000.isp-thi: initialized
[ 1.807412] pva 16000000.pva0: initialized
[ 1.838040] pva 16800000.pva1: initialized
[ 1.868535] nvdla 15880000.nvdla0: initialized
[ 1.898498] nvdla 158c0000.nvdla1: initialized
[ 1.900597] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.900642] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.900699] tegradccommon 15200000.dc_common: dma mapping done
[ 1.901358] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.901432] generic_infoframe_type: 0x87
[ 1.901532] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.901605] tegradc 15200000.nvdisplay: Display dc.ffffff800bce0000 registered with id=0
[ 1.905524] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.905566] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.905597] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.905858] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.905910] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.906911] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.909603] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.909636] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.913104] tegradc 15200000.nvdisplay: probed
[ 1.949215] Console: switching to colour frame buffer device 240x67
[ 1.949407] tegradc 15200000.nvdisplay: fb registered
[ 1.949849] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 1.950407] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.950520] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.965845] Parent Clock set for DC plld3
[ 2.028956] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 2.029617] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 2.029646] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 2.055206] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 2.055228] Extcon AUX2(HDMI) enable
[ 2.055547] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=85
[ 2.055571] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 2.055850] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 2.055887] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 2.056254] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 2.056273] tegra_cec 3960000.tegra_cec: probed
[ 2.057171] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 2.057736] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 2.066936] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 2.067792] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 2.067815] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.068206] kfuse 3830000.kfuse: initialized
[ 2.074520] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.077336] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 2.078671] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 2.079610] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 53, base_baud = 0) is a TEGRA_UART
[ 3.076498] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 3.141050] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -113.
[ 3.141078] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
��WARNING: pll_d3 has no dyn ramp
��[ 4.690086] console [ttyTCU0] enabled
[ 4.690160] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.690491] [drm] Initialized
[ 4.708922] brd: module loaded
[ 4.714730] loop: module loaded
[ 4.714805] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.714953] tegra_profiler: auth: init
[ 4.715376] nct1008_nct72 4-004c: starting parse dt
[ 4.715474] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.715481] nct1008_nct72 4-004c: success parsing dt
[ 4.715577] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.715775] THERMAL EST: found 3 subdevs
[ 4.715786] THERMAL EST num_resources: 0
[ 4.715795] [THERMAL EST subdev 0]
[ 4.715805] [THERMAL EST subdev 1]
[ 4.715812] [THERMAL EST subdev 2]
[ 4.715825] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.716204] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.716210] THERMAL EST: thz register success.
[ 4.716422] THERMAL EST: end of probe, return err: 0
[ 4.717218] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.717227] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.717923] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 461
[ 4.717938] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.728890] sd: No Scsi addr parsed to reserve index
[ 4.728931] hisi_sas: driver version v1.6
[ 4.731848] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 4.731858] Extcon AUX2(HDMI) disable
[ 4.734667] libphy: Fixed MDIO Bus: probed
[ 4.735494] tun: Universal TUN/TAP device driver, 1.6
[ 4.735502] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.736180] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.736187] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.736235] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.736241] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.736291] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.736297] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.736434] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 4.736445] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 4.747261] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.747816] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3a 86 70
[ 4.747832] Using phyrst_lpmode = 1 from DT
[ 4.747938] libphy: dwc_phy: probed
[ 4.750060] PPP generic driver version 2.4.2
[ 4.750291] PPP BSD Compression module registered
[ 4.750296] PPP Deflate Compression module registered
[ 4.750318] PPP MPPE Compression module registered
[ 4.750323] NET: Registered protocol family 24
[ 4.750381] usbcore: registered new interface driver r8152
[ 4.750424] usbcore: registered new interface driver asix
[ 4.750488] usbcore: registered new interface driver ax88179_178a
[ 4.750524] usbcore: registered new interface driver cdc_ether
[ 4.750582] usbcore: registered new interface driver net1080
[ 4.750616] usbcore: registered new interface driver cdc_subset
[ 4.750649] usbcore: registered new interface driver zaurus
[ 4.750698] usbcore: registered new interface driver cdc_ncm
[ 4.750859] VFIO - User Level meta-driver version: 0.3
[ 4.751310] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 4.752188] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.752202] ehci-pci: EHCI PCI platform driver
[ 4.752234] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.752245] ohci-pci: OHCI PCI platform driver
[ 4.752308] ohci-platform: OHCI generic platform driver
[ 4.753254] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 4.759083] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.760490] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.766005] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.766013] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.770946] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.776602] usbcore: registered new interface driver uas
[ 4.776689] usbcore: registered new interface driver usb-storage
[ 4.776904] usbcore: registered new interface driver usbserial
[ 4.781945] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.782016] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.783530] tegradc 15200000.nvdisplay: unblank
[ 4.785106] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.785340] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.786248] ucsi_ccg 1-0008: FW1 Version: gn v12.06, [Base 3.1.2.1487]
[ 4.786260] ucsi_ccg 1-0008: FW2 Version: gn v12.06, [Base 3.1.2.1487]
[ 4.787431] ucsi_ccg 1-0008: fw_mode: 2
[ 4.787436] ucsi_ccg 1-0008: fw1_invalid: 0
[ 4.787441] ucsi_ccg 1-0008: fw2_invalid: 0
[ 4.787446] ucsi_ccg 1-0008: silicon_id: 0x1f00
[ 4.787825] ucsi_ccg 1-0008: typec-port0 extcon dev created
[ 4.788068] ucsi_ccg 1-0008: typec-port1 extcon dev created
[ 4.788220] ucsi_ccg 1-0008: typec-pd extcon dev created
[ 4.788859] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[ 4.790912] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:1
[ 4.794886] ucsi_ccg 1-0008: HPI Command Success.
[ 4.797606] ucsi_ccg 1-0008: HPI Command Success.
< ... normal linux boot process continues ... >
