There are several device tree overlay .dts files under the ‘kernel-dts’ folder, and they will be compiled to .DTBO files under the /boot/dts folder. Then how and when these overlay are loaded? As known, I.MX use overlays.txt and Rasp use config.txt to indicate which overlays are loaded when boot. How L4T handle this? I need to know it’s behavior to add my overlays.
Ok, I know it’s cboot do the load action. Then which files are loaded? All dtbo files will be load? If so, I think I can compile my own dtbo files, and put them in the /boot/dts folder, then expect cboot will load them automatically, right? I need someone confirm this, 'cause we designed our own carrier board, and the GPIOs usage is different from the devkit, so Jetson-IO may not work well for us. Because it seems Jetson-IO limit the customation to the headers the devkit exported, but our board use some GPIOs not routed to the headers.
