hi
I am porting the camera driver in the following environment.
xavier@xavier-desktop:~/vsi/tpg$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64, DATE: Mon Jul 26 19:36:31 UTC 2021
Since the camera settings are bggr and RAW12, I set the device tree accordingly, but when I did insmod, a kernel panic occurred.
kernel_log.txt (75.8 KB)
mode0 {
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "bggr";
active_w = "3840";
active_h = "2160";
readout_orientation = "0";
line_length = "3840";
inherent_gain = "1";
mclk_multiplier = "11";
pix_clk_hz = "264000000";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "120"; /* 12dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "30000000"; /* 30 */
step_framerate = "1";
default_framerate= "15000000";
exposure_factor = "1000000";
min_exp_time = "2433"; /* us */
max_exp_time = "660000"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "2";
There are three things I checked.
- Through the call trace of the kenel log, I checked whether the fmt value in the camera_common_g_fmt function was null, and as a result, it was confirmed that it was null when set to bggr.
int camera_common_g_fmt(struct v4l2_subdev *sd, struct v4l2_mbus_framefmt *mf)
struct camera_common_data *s_data = to_camera_common_data(sd->dev);
const struct camera_common_colorfmt *fmt = s_data->colorfmt;
dev_dbg(sd->dev, "%s++\n", __func__);
if (fmt == NULL)
dev_err(sd->dev, "%s: fmt null (%p)", __func__, fmt);
else
dev_err(sd->dev, "%s: fmt no null (%p)", __func__, fmt);
mf->code = fmt->code;
mf->colorspace = fmt->colorspace;
mf->width = s_data->fmt_width;
mf->height = s_data->fmt_height;
mf->field = V4L2_FIELD_NONE;
mf->xfer_func = fmt->xfer_func;
mf->ycbcr_enc = fmt->ycbcr_enc;
mf->quantization = fmt->quantization;
return 0;
Added printk to the extract_pixel_format function in the sensor_common.c file to verify that V4L2_PIX_FMT_SRGGB12 is parsed properly.
Among the camera_common_color_fmts variable values in camera_common.c file, V4L2_PIX_FMT_SBGGR10 is present, but V4L2_PIX_FMT_SBGGR12 is not.
I think I can add V4L2_PIX_FMT_SBGGR12 to the camera_common_color_fmts variable, can you tell me how to add it? If not, is there any other way?
