• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version 8.2.5-1+cuda11.4
• NVIDIA GPU Driver Version (valid for GPU only) 510.68.02
• Issue Type( questions, new requirements, bugs) questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) export NVDS_ENABLE_LATENCY_MEASUREMENT=1
Hi, recently i found a question when i run deepstream-app program in the nvcr.io/nvidia/deepstream:6.1-devel container,
when i export NVDS_ENABLE_LATENCY_MEASUREMENT=1,
the results seems strange,here is the screenshot:
batch-num = 148 and batch-num=149 deals the same data, i choose 1 ipc and 3 files with file-loop for test, set streammux batch-size to 4, set yolov5 batch-size to 4 ,why come to this results?
here is my txt:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=4
#uri=file:/opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_1080p_h264.mp4
uri=rtsp://admin:zhy12345@172.16.72.64:554/Streaming/Channels/101
#uri=rtmp://192.168.0.14:1935/live/live999
num-sources=1
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
uri=file:/opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_qHD.mp4
#uri=rtsp://172.16.80.161:554/live/main_stream
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=3
uri=file:/opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_ride_bike.mov
num-sources=1
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=3
uri=file:/opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_1080p_h265.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=1
source-id=0
Indicates how fast the stream is to be rendered. 0: As fast as possible 1: Synchronously
sync=0
gpu-id=0
nvbuf-memory-type=0
codec=1
enc-type=0
qos=0
bitrate=4000000
iframeinterval=30
rtsp-port=8857
udp-port=5400
[sink1]
enable=1
type=1
source-id=1
sync=0
gpu-id=0
nvbuf-memory-type=0
codec=1
enc-type=0
qos=0
bitrate=4000000
iframeinterval=30
rtsp-port=8858
udp-port=5401
[sink2]
enable=1
type=1
source-id=2
sync=0
gpu-id=0
nvbuf-memory-type=0
codec=1
enc-type=0
qos=0
bitrate=4000000
iframeinterval=30
rtsp-port=8859
udp-port=5402
[sink3]
enable=1
type=1
source-id=3
sync=0
gpu-id=0
nvbuf-memory-type=0
codec=1
enc-type=1
qos=0
bitrate=4000000
iframeinterval=30
rtsp-port=8860
udp-port=5403
[osd]
enable=1
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
根据路数进行设置
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV5.txt
[tests]
file-loop=1
